Thread: Air in pump system, low pressure
    May 2014
    Houston, TX
    155
    How do I get air out of my pump system and raise the pressure back up to acceptable ranges?
    It was running fine and there was no air inside the pump filter basket, and no air bubbles were coming out of the returns in the pool. Then this morning, air somehow got into the system and the returns were bubbling and the water level inside the pump filter basket was getting lower. The pressure on top of the Hayward also dropped to almost 0. I tried opening the valve to release air, no dice. Tried filling pump filter basket with additional water, but no dice either.
    Here are some pics of my set up and the pumps:
    Here is where the water filter basket is, it's supposed to be full but when I turn off the pump and try to fill it, it won't fill... the most it can go up is halfway.
    I also tried opening the valve on top of the Hayward to get some air out, but it doesn't help much and the pressure needle on the gauge stays low while the pump runs. Sorry, pic is sideways...
    IG gunite pool size: 12,500 gallons - includes spa with spillover, Polaris vacuum cleaner, Ultrapure Ozonator, inline tab chlorinator that I no longer use
    Filter: Hayward Swimclear Model #4030, 4-Cartridge Filters
    Pump: Century, 2 HP with a Hayward 6060 booster pump
    Date of build: March-April 2014 *NEW* : Test kit: TF-100
    30,413
    Re: Air in pump system, low pressure
    If it has happened suddenly and was fine before, the first thing to check is the water level in the pool. Turn the pump on, go to the skimmer and watch to see if air is being sucked in. If so, add water to the pool. Report back what you find.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,974
    Round up the usual suspects: low water level, stuck weir (flapper) in the skimmer, loose drain plugs on the pump, poor seal on the pump strainer basket, and leaks at the fittings, especially any couplings. Since it happened all the sudden, it's not likely to be the drain plugs or the pipe fittings.
    May 2014
    Houston, TX
    155
    Water level was low, and the skimmer basket was clogged. Fixed those, and pressure came back right up to where it should be and virtually no air in the system. Thanks!
    30,413
    Thanks so much for the follow up. For others reading this thread, posting a follow-up (or conclusion) to your thread is VERY helpful to everyone.
    It helps us establish common causes for common problems and it helps people remember the solution should they have a similar issue.
    Thanks, again, yardoasis.
