Thread: lowering pH
    lowering pH
    There is a product in my garage from the previous owner called "pH Down." Can I use it? It contains 100% Sodium Bisulfate. There's a fair amount of it. Or should I use Muriatic Acid that I bought?
    Recent convert from Baq to BBB. My pH was 7.2 for the past month; now it's 7.8
    My numbers are:
    FC 5
    CC .05
    pH 7.8
    TA 70
    CH 100
    CYA 40
    Re: lowering pH
    We call sodium bisulfate "dry acid". It is fine to use to lower PH. Muriatic acid is less expensive, so long term I wouldn't buy any more dry acid. But if you already have it you might as well use it.
    Re: lowering pH
    Thanks. There's 2 small bottles and one large, so I'll try them and see how things work.
    Re: lowering pH
    Glad I found this post Just bought a used ABG and was given leftover chemicals... among them, 2 full bottles of PH down, and 1 partial that is hardened together (I may just pitch this one).
    I'd already bought a gallon of Mur.Acid for my ph, but now I know I can still use the Ph down as well if I need it.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist $600 w/part of deck included), 13,500 gallons, Intex SWG, solar panel
    My backyard is like a park... Why then does DH always want to go camping??? I just don't understand.
