Results 1 to 13 of 13
Thread: "Real" AGP and Salt Water Systems
    Mar 2014
    Chesapeake, VA
    74
    Just wanted to throw this out to the masses and see what sticks.
    I was in a pool place yesterday and asked some questions about 'real' salt-water systems. ie. Hayward Aqua-Trol etc.. they (Pool Place) said that it isn't recommended for vinyl lined pools, salt-water systems are usually for in-ground pools. They said the salt water would deteriorate the liner over time. The reason Intex gets away with it is their pools are a Vinyl/Canvas style liner. Plus if you use their (meaning Intex) it is ok on Their pools
    Is this a true statement, is it a bunch of garbage, or are there proven incidents with Salt Water systems ruining 'Real' AGP's?
    Dave Graham
    6,000 Gallon 16' x 4' Intex Round Ultra Frame
    Hayward S244-T Sand Filter, Intex SWG, Hayward SF1593 1.5hp Pump, Hayward Thru-Wall Skimmer
    Re: "Real" AGP and Salt Water Systems
    Total nonsense. The liner is going to be completely fine. Above ground pools have a small risk of an undetected leak causing the frame to rust when you are using salt, but the liner doesn't care at all.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Ruining liners? Hogwash! How about all those in-ground pools with vinyl liners? I think there just might be one or two of those on the forum!
    Mar 2014
    Chesapeake, VA
    74
    That is what I thought, and with the newer pools, they are more of a resin construction instead of the old metal. It was probably just the pool place trying to make more money on a fiberglass IGP. I won't be going back to this place at all, only thing I needed them for was my new access ladder for my pool deck I am still building, should be done in the next 24-48 hours.....Yep, just in time for Memorial Day weekend WooHoo!!!
    Dave Graham
    Apr 2014
    Gardners, PA
    69
    That is the biggest lie I have ever heard from a pool place. Chlorine is much harder on the vinyle than salt. Salt does not dry out vinyle like Chlorine will. Most places do not like salt water systems because it cuts into them selling you lots of cemicals.
    Mar 2014
    Chesapeake, VA
    74
    ah, that makes total sense. Their big product they were pushing for SW pools I want to say was Simple-Salt. Below is a snippit from the website. and I don't believe it one bit!
    <snip>
    The Simple Salt System offers such advanced technology that it is truly a low-maintenance system; set it and forget it! Just remember to test your pool water weekly. There is even a water temperature display and system active indicator so you can rest assured that your system is functioning properly.
    A 40 lb. bag of salt, one time only, on new pools will achieve a TDS (Total Dissolved Solids) level of 1000 ppm or greater, kick starting the natural minerals. This will enable us to get a clear reading when testing for copper. Again, the ideal range for copper is between 0.3-0.5 ppm.
    The Simple Salt System is environmentally friendly! By eliminating the need for daily sanitizers, we are helping the planet. You can even recycle the plastic chamber when the copper is depleted. When the chamber light illuminates, it is time to replace the chamber. The chamber will last one season on most pools. A number of factors will determine the life expectancy of the chamber such as pool size, weather, and usage.
    <snip>
    I am sorry, with my Intex SWG, I had to put 120-160# of pool salt in my pool, and it is 6000 gallons. how in the name of **** can you get a sanitized pool with only 40#??!?!?
    something sounds fishy and yes I live near the ocean so it isn't that
    Dave Graham
    Aug 2010
    Dallas, TX
    4,052
    Copper! Copper is great if you like stains and green hair. Our recommendation is to stay away from any of the copper or "mineral" systems.
    Apr 2010
    East Texas
    9,609
    They must be referring to a salt water aquarium. You simply misunderstood!
    Mar 2014
    Chesapeake, VA
    74
    and what's funny, is on their door, they had a sale on 25# of chlorine. I do have to admit, most pool places make their $$$$ on chems. not me, with help from TFP and my SWG, I am nice and crystal clear!
    now to get the TF-100 kit
    Dave Graham
    Mar 2014
    Chesapeake, VA
    74
    thanks for all the replies. It cemented what I was thinking, a bunch of hogwash/dirty water. LOL
    Dave Graham
    Well this is my 4th year using the copper/silver ionization system and my pool with non-chlorine weekly shock has been perfect! In fact they say you could shock every 2 weeks but I do weekly and it is crystal clear. It still smells a tad like chlorine. I have NEVER had algae or anything in my pool. I use the normal opening and closing kits everyone else uses. My copper level at times gets above normal but my blond gray hair has never turned green!
    Aug 2010
    Dallas, TX
    4,052
    You should only have to "shock" when absolutely necessary, which really should be NEVER. And, your pool should not smell like chlorine. From my experience and from what I learned on TFP, I can tell a pool in distress by the way the water looks and/or smells.
    Jun 2013
    Newcastle, Oklahoma
    508
    Quote Originally Posted by RobbieH View Post
    what is this "shock" term you speak of?
    forgive me, I am a BBB'r and am unfamiliar with this terminology....
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
