Thread: New Hayward S244T filter pressure drop from 14 to 12
    Apr 2014
    Mansfield, OH
    14
    Question New Hayward S244T filter pressure drop from 14 to 12
    All,
    Just had a Hayward S244T sand filter installed, it's been running about a week now. The first week, the normal operating pressure was around 14 PSI. I have had to backwash 3 times since cleaning the pool because of a battle with algea. Just yesterday after back washing, I have noticed that now it sits at 12 P.S.I instead of 14 now. Should I be concerned?
    -Dan
    20,000 gallon
    IG Vinyl Foxx
    Hayward S244T Pro Series Top-Mount 24-Inch Sand Filter with 1-1/2-Inch Vari-Flo Valve
    Pump ?
    Age of pool = 15 years old
    Jun 2012
    western NY
    1,562
    Re: New Hayward S244T filter pressure drop from 14 to 12
    It is hard to say as you only have a week of history on it. Is this the same pump feeding it that you have always had or was that changed too. What kind of pressure did you see from the old filter?
    One thing I tell people to do is get accustomed to feeling the flow from the return nozzles when you check the gage. I can tell within about 2# of what the gage is reading just by feeling the return flow. This way if something happens to the gage you have some sort of a backup.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
