Thread: Bubble trouble?
    May 2013
    Long Island NY
    419
    Bubble trouble?
    When my hayward super pump fires up in the mourning I get a lot of bubbles from the returns for about 30 seconds. ( it never did this last year)
    No leaks anywhere, so I did notice that my gasket is a little worn. Is this most likely the culprit even though no water leaks from the gasket.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Bubble trouble?
    It sounds like you likely have a leak somewhere on the suction side, possibly in the pump strainer basket lid.
    May 2013
    Long Island NY
    419
    Re: Bubble trouble?
    Yea, that's what I thought also. I will replace it and at least rule that out if it doesn't correct it. Thanks
    patrick3229's Avatar
    Feb 2012
    263
    Re: Bubble trouble?
    You can also try spraying soapy water around the lid on pump as well as any fittings on the the suction side and if you see the soapy water getting pulled in, then you have found your culprit.
    Thank You
    Patrick
    www.inyopools.com
    May 2013
    Long Island NY
    419
    Re: Bubble trouble?
    Just bought a complete set of gaskets for my Hayward pump series 1600 also fits series 2600 on eBay for $13.70 with free shipping.
    It comes with about 5 or 6 gaskets and seals.
    The best things is I don't have to go to a pool store.
