Thread: First Test with TF-100
    Jun 2008
    Lewisberry, PA
    31
    Received my TF-100 today and am very pleased. My first test results are as follows:
    PH: 7.3 - 7.4 (still a little hard for me to distinguish the colors, but more pink than orange)
    FC: 3
    CC: <0.5 (but there is some!)
    TA: 90
    CH: 170
    CYA: 60-70 (closer to 60, I think)
    I know at my CYA level I need to get my FC in the range of 5-9ppm, but do you think I need to shock the pool first? The CC test did turn pink and one drop turned it back to clear so I know there is some CC in the pool but less than 0.5. I figured I would leave the PH alone for now since I am using liquid bleach to chlorinate and shock and that should slowly increase the PH.
    The water looks real good and my pool description is in my signature.
    Am I on the right track?
    Roger
    14 x 28 Vinyl Inground, 13200 gal., Hayward EC-65 DE w/1hp Superpump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: First Test with TF-100
    I'd just raise it into range as long as the water looks good.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi astrolite,
    Here is a verbal scale (by Waterbear) that may help you with determing the pH colors:
    6.8 and below yellow
    7.0 yellow with a bit of orange
    7.2-7.3 orange
    7.4-7.5 red-orange
    7.6-7.7 red
    7.8-8.0 "pinkish" or "cool" red but not quite purple
    8.2 and above purple
    You're done SLAMing when:
