Thread: Newly automated... what do you think of my settings?
    onesickpsycho's Avatar
    Feb 2012
    Orlando, FL
    39
    Setup - 12k gal inground, w/ built in spa, Easy Touch 4, Whisperflo 2-speed pump, IC-20, solar only heat
    I finally converted to salt and bought the necessary actuators to fully automate. This forum has been a lifesaver as far as programming goes. I've run into a couple of issues and think I have solved everything, but would like someone to validate my settings (and provide any recommendations). I know it's impossible to do perfectly over the interwebs, so I'm not expecting a silver bullet.
    The big issue I've run into is that the salt cell doesn't get enough flow to run in spa mode. So I'm attempting to use the spillway setting to keep it chlorinated. Here's my setup currently:
    Sun-Thu - 8am-5pm - pool only, 5pm-7pm - spillway
    Fri-Sat - 8am-4pm - pool only, 4pm-7pm - spa mode
    We only use the spa at night on the weekends so I have it automated to make sure the solar can run and heat the spa each night. I'm hoping the spillway Sun-Thurs will be enough to keep it clean. Still working out the settings on the IC-20 to keep it chlorinated (50% currently and testing every couple of days - I know, I should have just gotten the IC-40).
    One question to confirm my suspicions - the lack of flow to the cell isn't going to screw anything up in spa mode, right?
    Otherwise, let me know what you think of my settings.
    Thanks!
    Re: Newly automated... what do you think of my settings?
    As little as one hour a day in spillover mode is sufficient to keep the spa chlorinated just fine. However, a three day gap, from Thursday to Sunday will lead to problems. You should adjust the weekend schedule so there is at least one hour of spillover.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    So when in pool mode, your spa doesn't get water into it to spill over into the pool? It only spills over when you have spill over turned on?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Feb 2012
    Orlando, FL
    39
    Quote Originally Posted by JasonLion View Post
    Ok, that's what I was worried about. I'll adjust accordingly.
    Quote Originally Posted by ps0303 View Post
    Correct.
    Thanks for the replies, guys!
