Results 1 to 10 of 10
Thread: Plumbing to pump down with
    Jul 2013
    Waxahachie, Tx.
    448
    This is a new install that I need to come up with a quicker way to pump down water level when it rains. The PB installed a bib valve to be able to attach a garden hose to pump down with. It works but, OMG!!!!! Boy is that slow. So having said that, I am looking for input to remedy this situation. I also have an idea. Put a 3 way Jandy valve in between the filter housing output and the salt cell. And use the input to the 3 way as the output. If there is a better way please speak up. Thanks in advance.
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Plumbing to pump down with
    For simplicity, I'd replace that hose bib with a bigger ball valve, then connect a section of pipe or a backwash hose to it. Hose bibs are seriously restrictive.
    Jul 2013
    Waxahachie, Tx.
    448
    Thanks that was one of another ideas I had....probably the simplest and least exspensive to do
    Jul 2011
    phoenix
    133
    What Richard said. I wouldn't bother cleaning the water your going to pump out. I'm in same boat have a hose bib in between pump and filter and need to remove some water due to cya levels
    13k IG pebble pool w/waterfall, 1hp whisperflow pump, pentair ccp320 cartridge filter
    Circupool SI45+ swg
    TF100 +speed stir Taylor 1766 salt test
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    +1 for adding a ball valve in place of the hose bib.
    Every pb should include a waste valve between the filter and pump if they don't use a multiport valve on the filter. At least once in every pool owner's life they will need to drain the pool to correct chemistry or make repairs!
    Love TFP? Become a
    TFP Supporter!
    Jul 2013
    Waxahachie, Tx.
    448
    I did a closer look and the adapter that the bib val screws into is gluded into place. So I have 2 options.
    1. Remove bib and put a 1/2" ball val in its place.
    2. 3 way jandy after the filter
    Richard320's Avatar
    Jan 2010
    19,075
    1/2" ball valve will flow probably 4X as much as that hose bib. That's what I'd do. If it isn't satisfactory, putting the hose bib back is no big deal and then you can start spending real money and cut pipes.
    Jul 2013
    Waxahachie, Tx.
    448
    Thanks for input. I am already leaning towards ball val.
    Jul 2011
    phoenix
    133
    Thinking of cutting out the T that has my hose bib threaded on and just put a new T with a ball valve and unions on each end of the T so for what ever reason I need to remove or change it I don't have to cut away any more pipe just build a new T with Same union pieces on each end to match.
    Question is would it hurt the amount of water out of the ball valve if you downsize it to have a hose thread onto it? That way can take a garden hose and just place it in yard
    Circupool SI45+ swg
    Richard320's Avatar
    Jan 2010
    19,075
    Quote Originally Posted by Iciee View Post
    Yes. If you go down from 1" pipe to a 5/8" hose, it will reduce flow. Still enough to fill the hose and run a sprinkler.
