Results 1 to 7 of 7
Thread: Stacking pavers?
    May 2014
    Louisville, Ky
    5
    Stacking pavers?
    My husband and I are having a heck of a time getting our yard ready for our new pool. We purchased an Intex 14' x 42" Ultra Frame, which is going in our extremely unleveled back yard. Our most recent issue is that we placed the pavers and made them flush with the ground before putting down the foam. My question is could we stack additional pavers using liquid nails or something similar so that they will be level with the foam? If not, we will have to dig down 2" more so the foam board is flush with the pavers or add dirt back under the pavers to raise them back up.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Stacking pavers?
    Welcome to TFP!
    You can stack the pavers, with or without the liquid nails. Adding dirt back under them is asking for the pavers to sink a bit, causing your pool to go out of level.
    As you are getting ready to fill your pool, start reading in Pool School, linked in the upper right of every page here. This will give you a heads-up on the best, least expensive pool care available!
    May 2014
    Louisville, Ky
    5
    Thanks for the input. Adding dirt under the pavers was my very last choice, but a choice nonetheless. My greatest concern with stacking the pavers was that they wouldn't be level and would possibly shift under the weight of the pool. The bottom paver would be firmly planted in the ground, but the top one wouldn't. Hence why I thought of an adhesive.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Welcome!
    I like your idea of gluing. If you get a bunch of kids roughhousing, there's no way to predict just what kind of damage they could do. Last thing you need is a shifted paver.
    May 2014
    Louisville, Ky
    5
    Richard 320, do you think the glue will cause the pavers to be unleveled? The bottom is already 100% leveled, but I was afraid the glue, depending on how thick, would cause the top one to be off, thus requiring us to reset the bottom paver. This is the first "real" pool we have set up so I am anal that it be done correctly!
    Richard320's Avatar
    Jan 2010
    19,037
    I don't know. How thick a bead will you be laying? If you spread it out with a mastic spreader or a notched trowel it'll only be 1/16" before compression/clamping. That's well within the tolerance, isn't it?
    Christian_peterson09's Avatar
    May 2014
    Wichita Falls, Texas
    2
    I would pull the pavers up and add crushed gravel, you can get this at Lowe's, and then use sand to help level the pavers. Finally I would fill the cracks with a polymeric sand. This will ensure a good sturdy base! Stacking seems to risky and adding loose dirt will just eventually wash out.
    18k, 16X33 IG Grecian Vinyl, Hayward S244t 300lb Sand, 1HP Pump.
