Thread: Hand turned color?
    Mar 2014
    Orlando, FL
    35
    Hand turned color?
    See below picture, not sure how this happened but I only have one theory.
    Theory is that I was doing weekly testing (all tests in TF100) and spilled something on my hand.
    I didn't notice until we were actually swimming though, so maybe something in the pool water reacted to it?
    Soap doesn't take it off, I'll try some something stronger later. Anyone have any guesses as to if my theory could be accurate?
    15k gal, Pebbltec. Built in 2004. 2 HP Pump, Cartridge Filter, Hayward SWG, Hayward Navigator Cleaner, TF-100 / Orlando, Florida
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Hand turned color?
    It could be the FAS-DPD powder. Look what it did to my box!
    Killer95Stang's Avatar
    Sunny SoCal
    591
    Did you a salt drop test? That test turns my hand purple every time I use it.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Mar 2014
    Orlando, FL
    35
    Indeed I did, and I dumped it out into my hands to fetch my speedster magnet. I will stop doing that!
    Mar 2007
    San Rafael, CA USA
    12,082
    The salt test uses silver nitrate and silver stains skin badly in a way that it won't wash out. It doesn't immediately show up and is absorbed into the skin, but exposure to sunlight then darkens it (just like in B&W photography where the silver ions get reduced to metallic silver). See this video for some bad stains and this video for the darkening of silver chloride.
