Thread: Pentair IC40 Low Salt Light Always On
    Jul 2011
    Limerick, PA
    28
    Question Pentair IC40 Low Salt Light Always On
    I think my SWG has died but wanted to get the opinions of some more experience folks!!
    My SWG was heading into its 4th season. It had been working fine through last season but after getting the salt level up to 4800 ppm, the SWG is still reading low. I have a salt meter and calibrated it using a standards solution (3000 ppm), and had the local pool store verify the same within 200 ppm. The manual says the salt level should be between 3200 and 4200, so I'm already high per the manual. I don't want to keep adding salt to see what happens but I'm thinking the unit has failed. I've power cycled the unit several times but no change. The water temp is about 67 but don't think that should be an issue per the manual. Would welcome any thoughts or words of wisdom if I'm missing something. Thanks in advance!!
    17x39 Rectangular, 20,000 Gal, Plaster, Pentair Easy Touch Automation and Remote
    Pentair WhisperFlow 2 hp pump with Pentair Clean & Clear Cartridge Filter
    Pentair Master Temp Gas Heater, Pentair IntelliChlor IC-40, Pentair Kreepy Krauly Legend II Cleaner
    ..and one frog that thinks the pool is his.
    Re: Pentair IC40 Low Salt Light Always On
    This is the normal symptom of a worn out cell. Cells typically last three to five years, so it seems reasonable that the cell might indeed be worn out.
    One thing to double check before you give up on the cell is to make sure that there isn't any calcium scaling on the cell, which can also give this same symptom. Looking in through the end of the cell calcium scaling is usually obvious as a white chalky coating on the cell plates. Given your symptoms, if there is calcium scaling it should be very obvious.
    Jul 2011
    Limerick, PA
    28
    Thanks Jason. I forgot to mention that I did acid wash the unit this before opening. The cell was clean and didn't exhibit any reaction to the acid wash at all. After about 2 minutes of nothing I emptied it and washed it out. I remove power from the unit during the winter but don't take it out. I'm wondering if this had some affect on the short lifespan.
    An acid wash will reduce cell lifetime, but only by a very very small amount.
    Everything points to the cell simply having lived it's normal lifetime and then worn out.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    I'm not convinced that it is the cell... however, the cell also houses the non serviceable sensor, and that would be why you would need a new cell. To get a new sensor.
    pity...
    Factory Warranty Station for:
