Thread: New to being "the pool guy" need help
    May 2014
    Algonquin, IL
    2
    I've inherited an ingound vinyl liner pool with overflowing spa. total volume 19,500 Gallons, Jandy 1.5HP Pump, New Hayward sand filter (24 gallon), Using TF Test Kit. I've been to multiple pools stores and everyone has a differing opinion on what to do to balance the water. Seems like a great way to procure $500+ from a poor pool owner every year at opening. I live in Chicagoland and we had a BRUTAL winter. The mesh loop lock cover is a nice safety feature but also a nice siv.
    So far, with the expertise of pool store, I've put about 40 pounds of granule shock and 19 gallons of liquid shock. Also about 31 pounds of alkalinity increaser. My TF Test kit #'s are:
    PH = 7.2
    Alkalinity = 240 ppm
    FC = 45
    CC = 0
    CYA = 70
    I need to have this water balanced and clear in the next 4 days... PLEASE HELP!!!
    Thank you in advsnce
    Feb 2012
    Cypress, TX
    131
    Re: New to being "the pool guy" need help
    How's the water look? Ph is a little low. FC is high but should go down on it's own, maybe in 4 days if you get a lot of sunshine. Cya is also a little high for IL. Might want to drain a bit out to lower. That should help with the high FC too.
    What kind of granular shock did you add? It may have raised your Cya even higher.
    Others will chime in soon to help too.
    23x40 freeform w/spa, 28,000 gal. PCC-2000 in-floor cleaning. Pebble Sheen w/flagstone coping. 14' weeping wall, (2) 18" sheer descents. Sta Rite- cart 400 sqft. filter, Intellipro VS pump, 1hp (cleaning)2hp (water feature)Max E Pro's. Easy Touch 8 function w/IPod. Rainbow chlorinator, Paramount Clear O3 (I know, I know), Max-E-Therm 400K heater.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,027
    Welcome, Jason!
    The big question is: what does the water look like? Clear with junk on the bottom? Hazy? Too cloudy to see through? Green? Black? Sludge? If it's just junk or hazy, you might be able to clear it in time. Otherwise, you might as well put the cover back on it.
    You've just discovered a big truth -- the pool stores don't always know what to tell you. If you want to get out of their clutches, get your own test kit and take control. There are only two test kits worth considering. The Taylor K-2006 or the TF100. Don't let a pool store sell you a K-2005. Despite the same box, it's not the same kit.
    Start reading some stories. If you think you can handle this, order a test kit and start reading the beginner pages in Pool School so we're speaking the same language.
    First Time Shocking with Bleach
    Pretty black pool
    A little encouragement for those with algae and new to BBB
    Frog Filled Green Swamp to Oasis---Work in Progress!!!
    Before and After Pool Pics
    Before and after!
    A final picture set of how well the BBB method works!
    Did any of those pool stores use the wheel of fortune?
    May 2014
    Algonquin, IL
    2
    i appreciate the response.
    I started with 10 # 73% Cal hypo
    Next Day 19 Gallons of 12.5% Sodium Hypo liquid
    Next Day 5# 73% Cal Hypo
    Next Day 24# 73% Cal Hypo
    The water looks great, actually looks swimmable... i can see the bottom, needs maybe 1 more vacuum...
    btw, thank you for the warm welcome... i;ve actually read quite a bit of threads here and stories, just getting to the point where its coming into focus!
    Not kidding, opened pool last Wednesday and last shock event was on Sunday.
    38,305
    Welcome to TFP!
    You are lucky that you were not using a different form of powdered chlorine or you would have worse problems, like high CYA.
    The numbers do not look too bad, besides the TA and FC being a bit high, but they will come down. You have a great test kit, so you are well on your way. What is the CH?
    How much of Pool School have you read?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Try adding a little DE to your filter. Since your water is a little cloudy the FC will kill off whatever is in there and the DE will help a sand filter pick up finer debris. Let your FC drop to slam level and keep it there until the water is clear, you have .5 CC or less, and you pass the overnight chlorine loss test .
    Please edit your signature to include information about the pool such as pool type (above ground or in ground), surface (vinyl, plaster, or fiberglass), size in gallons, pump brand and horsepower, filter type (sand, DE, or cartridge), filter brand and size, and any water features, cleaning systems, and if there is a spa (attached or detached). It will make it easier for us to help you if we don't have to hunt back through the thread for this information.
    Love TFP? Become a
    TFP Supporter!
