Results 1 to 12 of 12
Thread: 18 Dollar Shut off valves on my AGP
    Coonspool's Avatar
    Mar 2013
    Princeton, Indiana
    85
    I'd been searching threads looking how to install shut off valves on my filter and return.
    Seems like everybody went the way of hard plumbing everything.
    I thought I'd do a cheap and easy way.
    Maybe one day I'll hard plumb, but these are pretty nice for me, I love em already.
    Took me about an hour and only 18 dollars!!
    21' x 54" AGP Heritage 12,000 gallons.
    Hayward Power-Flo Matrix SP15922S 2 Speed 1 HP
    Hayward Pro-Series S244T 24"
    My SLAM Another swamp, is it worth it? Drain or gain?
    Casey's Avatar
    SW PA
    10,457
    Re: 18 Dollar Shut off valves on my AGP
    I need to do this! I'm not so hard pressed to go with all PVC. Looks good!
    andyrob2215's Avatar
    May 2014
    Portage, Indiana
    127
    How did you fasten the valve to the skimmer? Is it glued?
    21'x52 AGP 11200 Gal
    TFPC Method
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Quote Originally Posted by andyrob2215 View Post
    Sent from my SCH-I605 using Tapatalk
    I think the bottom of the skimmer has a threaded hole
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    May 2014
    Portage, Indiana
    127
    Gotcha thanks
    TFPC Method
    Coonspool's Avatar
    Mar 2013
    Princeton, Indiana
    85
    Yes I just remove the skimmer bottom 1 1/2 threaded pipe and put it on the opposite end of the shut off valve, I then put a 2 inch male to male connetion back into the skimmer part and screwed it back in. I did use teflon tape and silicone. My parts list was 4 items.
    2 1 1/2 shut off valves
    2 2 inch 1 1/2 male to male connectors.
    Casey's Avatar
    SW PA
    10,457
    Thanks for the pics!!!
    Stump's Avatar
    Jul 2013
    Oklahoma
    145
    Nice job coonspool! Shut off valves are so handy during cartridge filter cleaning.
    24' Reprieve RD/AG/13K gal Vinyl TFP method
    Waterway Clearwater 175 sqft Cartridge
    Hayward Power-Flo Matrix 1HP Pump 2-Speed
    TF-100 Test Kit SpeedStir Borate Insta Test
    Spreading TFP to All
    May 2014
    Portage, Indiana
    127
    Whether I hard plumb or not I'm definitely doing this!
    TFPC Method
    Jul 2014
    Kenosha, WI
    1
    Can I ask where you purchased the male to male connectors? I'm having a hard time finding them online.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You should be able to find them at any good PVC outlet. Like a sprinkler supply house. Online I would think they would be fairly easy to locate. You migh PM this poster to ask them for a faster response.
    Essential Links:
    Steve-in-VA's Avatar
    May 2015
    Smithfield/Virginia
    199
    Shutoff valves are great!! Just installed some on mine this year and hard piped it with quick disconnect unions.
    21,200 gallon/ 30' vinyl round above ground pool/ 200# hayward sand filter/1.5 hp hayward pump (70gl/m) /
    /self installed pool about 3 years ago - Smithfield, VA- Pool filled with well water -TF100 kit
