Thread: Memorial Day Weekend Pool Prep
    Apr 2014
    Dallas, Texas
    5
    We'll be hosting a pool party all Memorial Day weekend which means the pool will be occupied with friends and family the majority of the weekend starting Friday evening. Should the FC level be increased to prepare for the 'high traffic' in the pool or just monitor more closely and adjust accordingly?
    Constructed Setp. 2011 / 14K gallon IG Plaster / Pentair FNS Plus 60 DE Filter / Pentair Inteliflo Variable Speed 3hp Pump / Pentair Legend Platinum Pool Cleaner / Nature2 Inline Mineral Sanitizer / Pentair Inline Chlorinator (no longer using except when away from the pool for extended time)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Memorial Day Weekend Pool Prep
    Both.
    Search the word Party up at the top and you'll get find all kinds of advice and some horror stories.
    Dec 2012
    Manassas Park, VA
    207
    I also have two parties coming up, one on Saturday and another on Sunday. I believe the recommendation is to raise the FC by 2 before a party and by 2 after the party if possible.
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    Apr 2014
    Dallas, Texas
    5
    Thanks for the info, my fault for overlooking the obvious.
