Thread: Need help with a kiddie pool
    May 2014
    Atlanta, GA
    3
    Question Need help with a kiddie pool
    I recently purchased The Sizzlin' Cool Deluxe Blue Rectangular Family Pool (Designed water capacity: 307 gal. Product Dimensions 120" x 72" x 22",) my kids. I really don't want to have to keep emptying it every week, so I have a cover for it as well as a tester kit, and the chemicals to keep it clean and sanitized. I also purchased an Intex trading water pump: 530 gallon pump. I can't seem to get the pump to work. I've tried everything, but still nothing. Any help on how I can keep the pool clean from debris other things (other than a net, which I have,) would be appreciated.
    38,262
    Re: Need help with a kiddie pool
    Welcome to TFP!!!
    Do you mean that the pump will just not power up? If so, return it and get a functioning one. Is there a GFCI on the plug or the outlet? Could check that too.
    As far as cleaning it, a small battery powered vac might be a good solution.
    May 2014
    Atlanta, GA
    3
    No the pump turns on, but it won't pump anything. I've tried releasing the air valve on the top of the pump, but it still won't suck in any water or pump any out. The pool doesn't have any hook ups for a pump, so I've tried just putting the hoses over the side of the pool. I've added water to the hoses, but still nothing.
    Try using a water hose to fill the pumps hose while it's under water and pump turned on. This should help prime it.
    24k Ag pool, cartridge filter, 1.5 hp pump.
    May 2014
    Atlanta, GA
    3
    Quote Originally Posted by Burbs View Post
    Tried this and it still won't suck anything up. My neighbor suggested I turn the pump upside down in the pool, and by gosh that worked! I guess that will have to work. Thanks for input though.
