Thread: Best way to clean basket
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    What's the best way to clean this bad boy? I tap it against the side of the trash and all the loose junk falls out, but the wet debris just sticks in there. Anyone have any best practices? Thanks
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Best way to clean basket
    I have a faucet with a short hose and a sprayer near my pump. When it gets dirty, it gets the hose.
    Isolated Spa - 345 Gallons
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Jet stream on the hose nozzle. Do it over the lawn. Sometimes it needs a brushing from the outside to push the crud through.
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Hose, shooting from the outside in, and blowing the gunk back towards the top opening. Takes a bit of experimenting to get the right feel for how to do it quickly and efficiently.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
