Results 1 to 8 of 8
Thread: Deck foundation
    Jun 2008
    Marana, AZ
    347
    Deck foundation
    What should be the foundation for the deck supporting posts to rest on? Should I use concrete blocks? I don't want our deck posts to sink in the first rain!
    Our ground is fairly firm, btw. A hard rain can make it a bit mushy, though.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Deck foundation
    Where do you live? Winter weather is important when planning a foundation.
    Mar 2007
    Texas
    444
    Re: Deck foundation
    Dek Blocks
    27' Round AG, 17,200 gallons, sand filter
    Jun 2008
    Marana, AZ
    347
    Re: Deck foundation
    AZ - in the middle of the desert. Go months without rain, then it can rain buckets during the monsoon in the mid-summer. No bad frost, but we do get some below freezing nights in mid-winter, usually no colder than upper 20's, and once in a very great while (like once every 10 years or so), snow.
    I saw dek blocks on the net. That good, huh?
    Hayward sand filter
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: Deck foundation
    Check with your local codes department first, if you have one for the middle of the desert.
    I was thinking of using dekblocks too, but was told by our local codes folks that under no circumstances would they accept it. The requirements here are 16"x16"x12" concrete footers.. I just hope I never have to dig them back up.
    (If I haven't mentioned it, the codes people here are very anal - they wouldn't let me install the electrical feed for the pool - said I had to have a licensed electrician do it. Doesn't matter that I have a BS in Electrical Engineering...I don't have a license... )
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Mar 2007
    Texas
    444
    Re: Deck foundation
    Quote Originally Posted by Swimgirl
    Well My deck is built with the deck blocks, I have had mine since 2003, and have had NO problems at all
    May 2008
    Northwest Arkansas
    11
    Re: Deck foundation
    usually you only have to pour footings to a depth below the frost line to prevent "heaving." So I do not think you have that problem in a warm climate.
    lartay
    Jul 2007
    Suwanee, GA
    528
    Re: Deck foundation
    Quote Originally Posted by MikeInTN
    That's one **** of a footer for a foot traffic deck.
    Once great advantage of having an AGP is it's not permanent,so why should your deck be? I'd say blocks. I have no plans on moving my pool or deck for as long as I live here so I used Sonotubes buried at least 2' down.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
