Results 1 to 8 of 8
Thread: Just replaced 350lbs of sand, 2nd day i noticed a pressure drop.
    Oct 2010
    michigan
    284
    Just replaced 350lbs of sand. starting pressure 18PSi, checked couple hours later dropped to 15psi
    yesterday was 18psi to 16psi.
    can brand new sand end up channeling? or some other type of problem?
    none of the laterals where cracked, actually constructed very strong.
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    30,421
    Re: Just replaced 350lbs of sand, 2nd day i noticed a pressure drop.
    I would chalk it up to a sloppy gauge or something perhaps unexplained. psi should never go down until you backwash or clean your filter.
    Oct 2010
    michigan
    284
    http://tftestkits.net/Pressure-Gauge...Mount-p77.html
    just bought this gauge, only a week old.
    guess I could try putting the old on in and see if it happens again.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Low presssure usually means a restriction or air on the suction side. It could be as simple as low water allowing a vortex in the skimmer.
    It's conceivable something happened inside the filter, but that usually shows up right away. I'd look for air leaks, clogged skimmer, clogged pump basket, a valve in the wrong position, easy stuff like that, first.
    Oct 2010
    michigan
    284
    its the gauge, I put the old gauge back in, 19psi, put the new one in again 16psi.
    will have to return it.
    30,421
    Was it "pool sand" that you put back in the filter? If the sand was dirty, I suppose it could have been at a higher pressure initially and then forced some of the finest particles back into the pool but that is pretty doubtful. I'm gonna' think on that some more. I doubt it will happen again but that is interesting....keep us posted.
    It certainly couldn't be that VERY fine gauge you got.
    Check your PM's smooth2222
    Oct 2010
    michigan
    284
    20140521_134229.jpghere is a picture of the gauges
    new gauge on top, its getting worse. 14psi
    30,421
    That is quite strange. The "dirty" sand idea I had is bogus......it would only drop once.
    I really believe that new psi gauge is accurate but I am (for now) at a loss to explain why your pressure is dropping.
