Thread: Replace skimmer
    Mar 2012
    Columbus, Ohio
    16
    Replace skimmer
    My skimmer is cracked from a couple years ago and I have been patching it with pool putty. I bought a new skimmer to replace it. Will I have problems with the liner moving when I remove the face plate screws? The liner is two years old and is a unibead style that is hooked over the wall with a bead receiver over it. I am not worried about the top, only the cut out area and the screw holes lining up again. I will lower the water level a little below the skimmer bottom. Just a little afraid to remove it.
    24' above ground, 2008 Esther Williams, 13,500 gallon, 200# sand filter, 1.5hp pump, bottom drains.
    Adamsaudio's Avatar
    Jun 2013
    Atl
    36
    Re: Replace skimmer
    I need to do the same thing. I'm interested to see what advice you get.
    24 ft Round Above Ground - 13500 gallons... Former Pool Frog user. Sand filter . Located just South of Atlanta
    May 2014
    NY
    4
    Re: Replace skimmer
    Just did mine and liner did not move at all.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Replace skimmer
    Quote Originally Posted by willyk9 View Post
    Same here. Drain the water to just below the skimmer opening, and the liner should stay in place. While everything is taken apart, consider replacing the skimmer gasket if it looks beat up.
    Mar 2012
    Columbus, Ohio
    16
    Re: Replace skimmer
    Thanks! I feel better now.
    Adamsaudio's Avatar
    Jun 2013
    Atl
    36
    Re: Replace skimmer
    I ordered a skimmer from Amazon, got it replaced today. It was very easy. No problems with the liner moving. I'm finally drip free on all of my plumbing!
