Results 1 to 19 of 19
Thread: new owner outside chicago
    May 2014
    Chicago, IL
    12
    I recently purchased a foreclosed home. I have 30 foot above ground pool 4 foot deep. Based on what I have read I have been using 30000 gallons for all chem so far. now this pools was left untouched and uncovered for 2-3 years.
    initial kill off I used 5lbs shock and 15 gallons of 8% bleach over a 2 day period.
    cya is still at 0
    ph is 7.6
    cl 1.2
    calcium is between 350-400
    I am having trouble keeping the cl above 1. I have tablets in the filter basket at all times and am putting 1-2 gallons of bleach per day in it.
    I have some built ups scale on the outside wall of the pool and the water is very cloudy.
    going to try and raise the cya by adding some stabilizer hoping this will help with the cl issue. any ideas on the cloudy water and scale on the side
    30,426
    Re: new owner outside chicago
    Welcome to the forum.
    read "The ABC's of Pool Water Chemistry" up in Pool School. You need a refresher on the basics. Your CYA should be about 20-30 ppm and can only get in your pool if you add it.
    Your FC will not stay in the pool for 2 reasons.......you have organics in your pool that consume chlorine as they are killed and, most importantly, without CYA the sunlight will quickly destroy the chlorine which renders your SLAM useless.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Welcome, Matt!
    I hope you saved the empty bags of "shock" so you know what was in it. Powdered Chlorine will add either Calcium or CYA. So you might actually have some CYA in the water, just not enough to show up on the test.
    What test kit are you using?
    May 2014
    Chicago, IL
    12
    Taylor Complete FAS-DPD Kit
    it was a 5lb canister of shock and I tossed it.
    Richard320's Avatar
    Jan 2010
    19,037
    May 2014
    Chicago, IL
    12
    last nights #'s
    1700
    fc 0
    cc .5-1
    PH7.2
    CYA still showing 0 but there has to be some in there
    started the slam with 4 gallons of 10%
    1730
    fc 10
    cc>.5
    added 4 gallon of 8.4 % bleach
    1830
    FC 20
    CC>.5
    1930
    FC 20
    cc>.5
    since it stayed the same over the hour I left it alone overnight to see how it held up
    this morning
    FC 10
    forgot to check CC
    Will start the slam again when I get home see if I can get the FC to hold overnight. The water is still very cloudy. I am getting a 10% raise in psi every 24 hours so I am backwashing every day. Was going to get some DE to add to the sand filter today when I get home see if that helps.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Welcome neighbor....Keep us posted. Where outside Chicago?
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by MattP22 View Post
    Will continue the SLAM when I get home see if I can get the FC to hold overnight.
    I changed a couple of words above. It's a subtle difference, but it's very important. The whole process is the SLAM process (even if you have to let up on it a little to go to work).
    Don't bother with the DE yet. If you're going up 10psi every day, the filter is working fine, and adding DE at this point will only slow the process.
    May 2014
    Chicago, IL
    12
    I live in Sycamore, IL easier to say Chicago fro climate purposes.
    11,969
    There's a great restaurant with a nice martini list in Sycamore. Drawing a blank on the name...
    Good luck - let us know if you need anything....
    May 2014
    Chicago, IL
    12
    I have to imagine that would be Nats on Maple
    May 2014
    Chicago, IL
    12
    slammed it again Friday and it held FC overnight. was out of town sat and Sunday and came back to FC4 cc 0 ph of 7.1.
    I though it was strange that ph went down while I was gone since I didn't;t do anything with it.
    water is still cloudy. I was in it yesterday and there is a white powder that comes off the side walls when touch it so I ran the vacuum along the walls to see if it helps. would this be to the high calcium?
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Glad to see I'm not the only one from Sycamore making a go of it.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    May 2014
    Chicago, IL
    12
    think I bought Walmart out of bleach had to hit up target on Friday night.
    Oct 2013
    Chapin, SC
    1,141
    Something's missing here-how much cya did you add? In the OP you mentioned keeping tabs in the skimmers-are they perhaps cal hypo tabs? My gut tells me your powdered cl was cal hypo.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    May 2014
    Chicago, IL
    12
    Not sure on how much CYA is there. Since I added 5 lbs of powdered shock and probably 7-10lbs of pucks have gone in it. I am guessing there is some CYA there but the test was still registering 0 on friday. I was going to wait a few more days and test CYA again see if it registers.
    Oct 2013
    Chapin, SC
    1,141
    You said you are going to try to add some cya, so how much did you add? 2lbs, 4lbs? not asking for ppm. Assuming you still have the bucket of tabs, what kind are they? You said you threw out the canister the powder came in so there's no way of knowing what that was. I'm trying to figure out how much cya you might have in your pool if any. As far as I can tell all you say is there is 0 based on some kind of test.
    May 2014
    Chicago, IL
    12
    I have not added any CYA yet. I was going to ask what would be a good CYA target to have
    Oct 2013
    Chapin, SC
    1,141
    Aha! So you're kind of depending on any cya you think was added by all that shock and tabs you've used that may not have any Stabilizer in them? 30- 50ppm is a good starting point. Half at a time, then retest to see how much more you need.
