Thread: How much household bleach do I need?
    May 2014
    Ohatchee, AL
    1
    Smile How much household bleach do I need?
    I have a 30K gallon pool and am thinking of using household bleach and need to know about how much will I need to start bringing my chlorine levels up?
    HacoboPablo's Avatar
    Jun 2013
    San Diego, CA
    63
    Re: How much household bleach do I need?
    Welcome to TFP! Sounds like your on the right track switching to straight chlorine instead being pool stored. First you should get a reliable test kit.
    You can compare test kits here: http://www.troublefreepool.com/conte...its-comparison
    I recommend this one, it has everything you need and a good value: http://tftestkits.net/TF-100-Test-Kit-p4.html
    Also the more info you post about your pool type, equipment, etc the better help you'll get. Read this: http://www.troublefreepool.com/conte...efore-you-post
    Intex AG 14'x42" Ultra Frame | 3357 Gal (3500 Gal from pool calc.)
    Intex 16" Sand Filter/2650 gph pump & Intex 54601EG SWG, Hayward SP1091LX thru-the-wall Skimmer, Intex Magnetic Pool Light, TF-100 test kit w/SpeedStir & Sample Sizer.
    Our first little Intex pool project...
    Apr 2014
    Indiana
    106
    Use the "PoolMath" calculator up top ^ there.
    For 30,000 gallons to get from 0 to 6ppm you will need 271 ounces of 8.25% bleach or 373 oz of 6% bleach and you'll have to add more every day.
    Of course, we would need more details to help you any more than that. Without an accurate water test for all the chemical levels, there's not much advice we can give. Get some good test results and post them!
    22,000 gallon in-ground kidney-ish shape: 1 HP pump and Triton TR60 sand filter. NEW: Dolphin Nautilus robot! :)
