Thread: Do I dilute Borax and baking soda
    May 2008
    Webb City Missouri
    28
    Do You dilute the borax and baking soda before you put it in the pool or just sprinkle it in. Do I do it near the intake and outlet?
    Tysnest
    18x33 AGP
    16000 gallons
    Waterford 1 1/2 HP/2speed
    Waterford High Rate Sand Filter 21 inch tank
    SunGrabber Solar Panels 3 2x20 ft panels
    New at this pool and clueless
    Guest
    Re: Do I dilute Borax and baking soda
    IF you are using borax to raise pH then just pour it slowly into the skimmer. Ditto for baking soda to raise TA. If you are adding borax to add borates to 50 ppm (which is a different use than raising pH) then the procedure is a bit different and is covered in this thread:
    viewtopic.php?f=8&t=4921
    May 2008
    Webb City Missouri
    28
    Just adding to raise. Thanks for your quick response. This site is the best!!!!!!
    Tysnest
    18x33 AGP
    16000 gallons
