Results 1 to 18 of 18
Thread: clorox shock
    Jun 2013
    Huffman Tx
    190
    clorox shock
    New brand at Lowes , does this have stabilizer in it ? Is this just the same old stuff with new branding
    Jun 2013
    Huffman Tx
    190
    Re: clorox shock
    pics
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: clorox shock
    It is a bit blurry but I think that says trichlor under ingredients, so it is stabilized
    Jul 2012
    Harpers Ferry, WV
    37
    Re: clorox shock
    It says it's tri-chlor.
    8600 gallons (18' x 4.5' round), Sherlok 120 Cartridge filter, AG installed 1999, Hayward Matrix Pro (2013), , well water topping off fill by Fire Dept. (2013)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: clorox shock
    Took some hunting....
    Pool stuff is not on the Clorox page, it's here: http://cloroxpool.com/msds-info/
    That "shock" is just trichlor and boric acid and soda ash MSDS Since it has trichlor, yes, it has stabilizer.
    Another complication to confuse new people.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: clorox shock
    Looks like trichlor with pH increasing compounds to offset normal pH drop that usually happens with trichlor?
    Isolated Spa - 345 Gallons
    Re: clorox shock
    It's not on the Clorox page, because Clorox just rented out the name. I wondered who was really behind this company. According to this article it is KIK Custom Products who purchased Chem-Lab (which we've seen before). They have a subsidiary, Easy 1 2 3 Pool Care LLC, that has a licensing deal with Clorox to use the Clorox on their products.
    I found another article that's very pessimistic about this venture.
    “If you asked someone, ‘Hey, what chemicals are you putting in your pool?’ They wouldn’t have a clue,” says Art Harre, president of pool and spa products for Haviland USA.
    20,000 gal in-ground plaster pool with sand filter. Replastered recently. Mostly adding bleach and acid. CYA was high when I took over.
    Re: clorox shock
    They had Clorox brand muriatic acid at Lowe's today for $2 more than the KemTek brand and it's made by the same company! I guess they're hoping people will pay more for a familiar name.
    Re: clorox shock
    I think that Clorox brand muriatic acid is bound to cause confusion. Also, the product says this:
    Compatible with Salt Pools....... No
    I'm not sure why they would say that it is not compatible with salt pools.
    Support the site
    38,275
    Re: clorox shock
    We have seen that label on other muriatic acid as I recall .... weird.
    Apr 2014
    Idaho
    14
    Re: clorox shock
    They even have easy to use "chlorinating liquid!" http://cloroxpool.com/product/chlorinating-liquid/
    I wonder how much they charge for this bottle of bleach?
    15 ft x 35 ft, 20,000 gallon IG Plaster, Sta-Rite Cristal Flo II Sand Filter (3.15 ft2/300 lbs, 70 gal/min), Sta-Rite Pump (1 HP), Pentair MasterTemp 400 Heater (400,000 BTU), CoverStar Automatic Cover, Kreepy Krauly Sand Shark Vacuum, Built April 2014
    38,275
    Re: clorox shock
    That is just 10% instead of their usual 8.25% strength.
    Re: clorox shock
    Quote Originally Posted by gbod View Post
    At Lowe's recently Clorox brand chlorinating liquid was $4.88 (10% 1gal). Kem-Tec was $3.68 (10% 1gal). So you pay 30% for the name brand on the label. The stuff is probably from the same plant.
    The KT brand is slightly cheaper that what I pay for GreatValue per chlorine oz, but they keep it outside at the Lowe's that carries it. Since 10% degrades faster, I'm not convinced it would actually be cheaper, but I'm drifting over to the bleach prices thread.
    Jun 2008
    Marana, AZ
    347
    Re: clorox shock
    That is funny!
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Jun 2014
    maricopa az.
    1
    Re: clorox shock
    What about calcium, it doesn't say calcium free?
    Re: clorox shock
    It doesn't contain any calcium, at least none is mentioned in the ingredients list.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: clorox shock
    I read about this in Pool and Spa News a several months ago. You can read about it here;
    http://www.poolspanews.com/chemicals...pa-market.aspx
    i was thinking at the time that this will confuse a lot of people.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: clorox shock
    That Pool and Spa News article is very telling:
    For one retailer, the main worry is consumer confusion. “My first concern is that customers might go back to assuming they can put Clorox [bleach] in their pools, which we try to educate them [against],” said Susie Hoskins, co-owner of Olympia Pools in Fort Wayne, Ind.
    Oh the horror of people using Clorox (or any other brand of) bleach in their pools! That cat is out of the bag. So long as there aren't additional additives in it (e.g. thickeners, scents), bleach is bleach whether it's from a grocery store, big-box store, or pool store. Chlorinating liquid is just concentrated bleach. So buy what is affordable, convenient, and/or ecological (reusing/exchanging bottles).
