Thread: Refilling the Pool!
    Refilling the Pool!
    Hi, y'all!
    I'm filling a large community pool after a draining for various maintenance. it's going to take another day or two fill completely, so my queston isd, when should I begin hitting the pool with BBB? Ph is pretty good already (7 to 7.2), though our present testing resources are old. Calcium is WAY low, alkalinity a bit low.
    Should I start guessing now, as it fills, or wait a bit until the pool is full?
    Thanks for your help!
    80,000 gal community pool
    Painted concrete
    Dual Triton 125 gpm sand filters
    Generally you want good circulation when adding chemicals. If it is only going to be a day or two I would wait till you have the pump running.
