Thread: Hayward Ecostar SP3400VSP trips the breaker and won't start....
    Need some help or opinions....
    The pump is 2 years old. Last couple of months the pump stopped few times with Error- Pump has stalled. After turning the power off and on everything was ok and pump was working fine. Now it stopped completely and trips the breaker every time I turn on the power or switch the breaker to on position. Local store where I bought the pump is not helping as the pump is out of warranty. I took the pump to local pump repair place and they said most likely the motor is fried but it could be the panel as well. They can't tell exactly where the problem is. They did confirmed same issue with tripping the breaker as soon as you turn on the power.....someone had similar problem with the pump ?
    Mar 2014
    Cape cod
    8
    Re: Hayward Ecostar SP3400VSP trips the breaker and won't start....
    Im more of a pentair guy than hayward so not sure exactly how that pump powers up. If the breaker trips before the screen even lights up I'd say you have a bad drive on the motor.
    Oct 2012
    Maricopa, Arizona
    109
    Iíve run into the same problem. Tried turning off the power and back on. Tried changing the rpm setting as was posted elsewhere. Neither has worked. Looks like I have to call Hayward.
