Results 1 to 8 of 8
Thread: Next Step?
    nthoms's Avatar
    Jul 2012
    Colchester, CT
    36
    Next Step?
    I have a 22,500 gallon, vinyl lined, cartridge, salt water pool.
    The water looks good.
    FC: 5.0
    CC: 0.2
    TC: 5.2
    PH: 7.2
    TA: 70
    CH: 70
    CYA: 60
    SALT: 2600
    TEMP: 75
    Any advice on my next steps ... I am concerned about the PH being low (7.2).
    I have stamped concrete surrounding the entire pool ... should I also be concerned about the Calcium Hardness (70) being low?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: Next Step?
    Your calcium hardness is fine in a vinyl lined pool. That SWG will most likely tend to make your Ph rise due to turbulence in the cell. CYA might be a tad low.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Re: Next Step?
    The next step is to turn on the heater. 75 is too cold to swim in!
    Those readings are great! The SWG will probably drive the pH up a bit. There's no point raising pH today only to have to lower it again in three days. You don't need Calcium for the vinyl pool, and I wouldn't worry about the deck. Rainwater has no Calcium, and it hasn't dissolved it yet, has it?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Next Step?
    How old is the system? is there a heater? I can see your question about the cement - it goes right to the edge? no coping?
    You can hold off on the PH for a few weeks and see if the PH drifts up on its own from the SWG, or maybe bump it to 7.4 with Borax.
    What is the recommended level for your salt system? 2600 seems a bit low.
    Good points Richard!
    nthoms's Avatar
    Jul 2012
    Colchester, CT
    36
    Re: Next Step?
    Quote Originally Posted by woodyp View Post
    Thanks
    Thanks for the information
    I have an Electric HeatPump ... can I run an extension cord to your house ?
    Nope ... the deck looks great! I just need to put on a coat of sealer as its been a few years. Any advice on cement sealers???
    nthoms's Avatar
    Jul 2012
    Colchester, CT
    36
    Re: Next Step?
    Quote Originally Posted by frustratedpoolmom View Post
    --7 years old.
    Is there a heater?
    --Yes (HeatPump).
    --There is coping around the edge.
    --OK. sounds like a good plan.
    --3400 is the recommended level ... I worry about so much salt around the cement so I tended to keep it low. Am I wrong with my assumption?
    30,426
    Re: Next Step?
    Only if your SWG ois not genertating chlorine. If it's working, that's all that counts.
    nthoms's Avatar
    Jul 2012
    Colchester, CT
    36
    Re: Next Step?
    The water still looks great.
    However ... my PH is dropping. It was 7.2, now it's barely reading 7.0
    FC: 5.0
    CC: 0.2
    TC: 5.2
    PH: 7.0
    TA: 70
    CH: 60
    CYA: 45
    SALT: 2900
    TEMP: 82
    SATURATION: -1.37
    Any advice on my next steps ... I am concerned about the PH being below (7.0). Should I be?
