Thread: Keywords search
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Keywords search
    Correct me if I'm wrong, but if one wants to find posts which contain both words "A" and "B" one should list the keywords as A +B (or +A +B.)
    When I search for A + B the search results lists also posts that contain just A.
    Please check and advise.
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Keywords search
    I still have trouble using the search feature.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Keywords search
    Very common words are ignored. For example the query "check +pool" ignores the word pool so it returns all listings with check in them. There will be a little message in upper left telling you what terms were used for the search when the results are displayed.
    For example, try searching for fiesta +salt and you get:
    fiesta +salt ignored: salt
    And the posts contain only the word fiesta.
    It can be frustrating because words like pump, chlorine, pool etc. are ignored when searching.
    If that's not what's happening, post your query and I'll try it as well.
    John
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Re: Keywords search
    Has someone fixed something after I posted?
    This is strange.
    Before the original post I searched for Liquidator +easy.
    I had gotten back some results that contained the keyword "Liquidator" only and
    some with both "Liquidator" and "easy".
    I repeated the search just now, and lo and behold - the search results contain both keywords!
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Re: Keywords search
    If you use the search link at the top of the page, you'll find you have option as to how and what to search. Try playing around with those.
    Also, at the bottom of every page you will find a site specific google search tool that is getting better each day. After the upgrade, the urls changed so it's taken awhile for the site to get fully indexed again, but I think you'll find it gives good results now.
    You can use either one - just trying to provide options.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Re: Keywords search
    I did a search for Liquidator +WS, and although it came back with "WS ignored"
    I got many search results which contained both "Liquidator" and "WS" highlighted in yellow.
    The site google search got only five results. I understand the indexing takes time.
