Results 1 to 10 of 10
Thread: Brand new pool owner of gunite pool...got a question (with pic)!
    May 2014
    United States
    5
    We bought a repo house over the winter that had a pool. The pool was not winterized properly and was extremely dirty. We were advised to empty it, power wash it and then acid wash it...which we did all of this. We did a LOT Of scrubbing and cleaning and it looks much, much better but still looks quite dirty. How much of the black looking stains can we expect to disappear with chemicals? The picture is what it looks like now, as it is refilling.
    Thanks for any suggestions, help with our "money pit"!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Brand new pool owner of gunite pool...got a question (with pic)!
    Welcome to TFP
    I think you should test to see if those stains are black algae. To do this, gently scrape a sample of the suspected black algae with your fingernail and then smudge it on plain white paper. If the smudge scrapes off and is a greenish color, then itís black algae. Although everything you did (power washing & acid washing) should have removed this, it is a simple enough test worth doing. Post back with the results of this test.
    Of course, those stains could be something else and someone may be along to offer other alternatives.
    30,421
    Welcome to the forum.
    Impossible to say without identifying the stain as organic or inorganic first. It looks sorta like streaking. How long has it been there?
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    I would not fill till you've identified what the stain is as others have mentioned.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    That pic is the "after" after an acid wash?
    May 2014
    United States
    5
    Thanks...we will test them as suggested. We were told the previous owners used the pool recently (within 1-2 years) We just bought the house 5 months ago in the winter so we had no idea the condition of the pool until we took the cover off about 3 weeks ago. The streaking appeared after the acid wash...as the acid wash was running down the slope of the pool it made the "streaky" look. Before the acid wash it was covered in it. We did try scrubbing, etc and pouring more acid wash but this is as good as we could get it. Thanks again!
    Yes, the picture is after the acid wash
    May 2014
    United States
    5
    also, as it fills up should we add any chemicals or just let it fill first? Should the pump be on? Sorry we are newbies!
    11,969
    Let it fill. Pump won't run until it can prime (water needed) if you can isolate the main drain by closing off any skimmer valves you can run the pump on the main drain, but I'm not sure that's necessary at this point.
    Have you read Pool School? Do you know our recommended chemicals? And how do you plan to test the water....
    May 2014
    United States
    5
    So, frustratedpoolmom...do you recommend continuing to fill it? Someone else said not to fill it so I just went and shut off the hose. I assumed since its half way full now I should just go ahead but now I am not sure what to do!
    We did attend a local pool school at Watsons and got some knowledge. My husband may know more about the chemicals than I do. We have test strips
    May 2014
    United States
    5
    Basically, just wondering if anyone can tell me if the black spots can/will disappear with chemicals
