Thread: Stuck winterizing plug
    May 2014
    Big Rapids, Michigan
    1
    Exclamation Stuck winterizing plug
    This is my first go at opening my pool, we installed it last summmer. I am having trouble removing one of my winterizing plugs on one of my step jets. The plug is the white pvc with an oring on it. When I tried loosening it, the entire housing would spin. Is there any trick to get the plug out? Also, I've noticed sand coming in from behind the white flange/trim, did I create a leak? Should I try turning the plug back in the "tight direction" to see if the housing will stop spinning?
    Oct 2013
    Chapin, SC
    1,141
    Re: Stuck winterizing plug
    If your return jets are the same as mine, they screw out completely. I took mine out to install an aerator.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
