Results 1 to 9 of 9
Thread: possible for Instant Pool Water Conditioner (liquid CYA) to be too old?
    Jul 2012
    Herndon, VA
    419
    I found an unopened gallon of this Natural Chemistry Instant Pool Water Conditioner in my garage. Previous owner left it for me. It's been there at least two years in a garage that gets hot in the summer, cold in the winter....
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    30,419
    Re: possible for Instant Pool Water Conditioner (liquid CYA) to be too old?
    Is there a question?
    Jul 2012
    Herndon, VA
    419
    is it possible for Instant Pool Water Conditioner (liquid CYA) to be too old?
    30,419
    Probably not. Why not add a small dose (say 10 ppm if you can afford the extra CYA) and see if it shows on the test?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    If its there and was free and you need to add it... you can add it, and then you'll know. LOL sorry, couldn't resist....
    Jul 2012
    Herndon, VA
    419
    I did add it yesterday.....
    it was actually a bit granular and clumpy....clumps settled to the bottom, but dissolved relatively quickly by brushing. I'll test CYA later today to see if it's still effective.
    11,969
    A client just added a brand new bottle - it was clumpy too. Keep us posted!!!
    Jul 2012
    Herndon, VA
    419
    just checked cya.
    registering around 40.
    I checked yesterday and had zero....but the water was only 67 degrees. I didnt realize until today that water should be at least 70 degrees when testing cya, so I heated the pool to 72.
    Oct 2013
    Chapin, SC
    1,141
    Room temp is good enough and uses a lot less electricity. If in a hurry, holding your sample bottle under warm tap water will do too.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
