Results 1 to 7 of 7
Thread: Backwash frequency?
    Backwash frequency?
    Hi everyone,
    This is my second summer with my 24 feet AG pool. I have read here (and at many other places) that I should do a backwash when the pressure (indicated on the sand filter gauge) is 6 to 8 psi above 'normal' -- with 'normal being the pressure shortly after a backwash/rinse.
    So, I decided to let the pressure going up and see how long it would take to let it go up 4 or 5 PSI. It has been 3 weeks and my pressure is still the same: the gauge has been indicating 16 for the last 3 weeks. Can it be that long? Should I backwash anyway or keep waiting until it gets to 21 PSI?
    BIC
    Don
    SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter
    Pentair Intelliflow pump
    Pentair SWG
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Backwash frequency?
    You are probably fine. I go a month or more in normal conditions. As long as you have good strong flow into the pool it's fine to operate with the filter a little dirty. It actually performs better.
    I usually backwash when the water is too high on the skimmer because my fill water has TA issues. Typically the only time my pressure goes up is after a lot of wind and vacuuming.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I have never understood the recommendation myself. My pressure gauge stays consistent on the various settings: 3 on low 12 on high, 15 on bottom drain/high.... My cartridge filter hadn't been cleaned since the end of May, so I KNEW it had to be filthy, as the heater was being tempermental, which usually is a sign of a dirty filter. Pressure gauge didn't fluctuate tho. So I cleaned the filter yesterday anyway, it was downright icky.
    I don't think its the gauge per se, it's always been this way for 7 years now.
    One thing I did notice was a greatly improved flow from the return. Gauge still at 3!
    Thanks for the responses everyone.
    I thought that 3 weeks was way to long between each backwash, I do realize now that it is not bad to wait that long. I just did my backwash and it did improve a bit the flow from the return
    BIC
    Don
    SW Florida
    Pentair SWG
    Shelley N's Avatar
    Denver, Colorado
    199
    I'm glad this topic is up. My pressure gauge came out of storage broken this year. This is our 3rd year with our pool. Since my pressure never rose more than 2psi the entire summer last year, I was wondering if I could go without it and just backwash when I felt the return get a little low.
    Shelley
    Denver, CO
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    ShelleyN, that's what I do. Our sand filter's guage was messed up this spring so we replaced it and the stupid thing still never goes up. Stays at 10 when no solar and 11.5 with it. Often after vacuuming, the return will have low pressure(guage still the same) so I backwash and the return pressure goes back up.
    HTH,
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    SW Indiana
    9,199
    Quote Originally Posted by Shelley N
    You can buy a new gauge for $4 at a farm store, and it's pretty important for knowing what is going on with your system.
