Bleach and Chlorine?
DeeDee
Jun 11, 2013
28
Houston, TX
I'm planning on using bleach but my CYA level is 30, and I want to raise it using my chlorine tablets in my chlorinator since I have 75 lbs. of it. My question is... Should I just use my tablets until the CYA is up or should I use bleach and tablets?
It sort of depends on whether or not the tablets dissolve fast enough to maintain an adequate FC level. Testing will tell you.
If you scroll down to Effects of Adding Chemicals on Poolmath, you will see what each 8 oz trichlor puck will do to your pool chemistry. Note that they will mess with pH. If you're always fighting rising pH, that might not be a bad thing. But do use that to estimate how many pucks you can safely add, and do not use any more than that.
