.What cancels out most of the advantage in chlorine now is this...An extra gallon every couple of days is a lot cheaper than trying to clean a green pool
If you add chlorine now, the chlorine ends up working on the solid organics that are in the pool and I doubt you'll see significant progress.and the deep end drain is pretty clogged with leafs. I get the keys next Wednesday so i have to wait to throw a vacuum in and rake out the leaves until then.
When OP reports a pool with a lot of solids in it, we think it is a good idea to net out the solids first, make sure the circualtory sytem is up to speed and then SLAM.
There is no harm at all in putting in some chlorine now but the advantages of doing so are normally offset because of the solids in the pool.
