Thread: Hayward heat pump lp code
    Aug 2013
    Brighton, MI
    62
    So the heater is throwing an LP code after a few minutes of runtime. I think it ran for most of the day without issue. After some reasearch, it appears it could be an airflow issue, low ambient temp, or low refrigerant. When it runs, the exhaust is cold and the water output warm. The ambient temp was 75 so I don't think that's it. Could it be a bad lp switch so it cut out when it was cooler but way above where it should have? Is there a way to verify that it's not refrigerant? I'm wondering if I can fix this or if I should call someone.
    Thanks!
    20 x 40 28k gallon Salt Water Vinyl IGP, Hayward pump and Sand filter
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: Hayward heat pump lp code
    Unless you have the gauges to measure the refrigerant, you need to get a qualified company involved. Lots of AC companies service heat pumps.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Aug 2013
    Brighton, MI
    62
    So after further diagnosis, it turned out to the fan motor. I canceled my service appointment and spent 2 hours on the phone trying to track one down locally. Finally found a compatible replacement locally for 130 bucks. The hayward one is about 165 online. The wiring was a little different, as the new one had an extra wire to the capacitor. I figured that the hayward model just tied this to the low side internally, so that's how I wired it. The new fan motor is larger, so had to be careful with clearances. Fired it up and it worked! Pool temp raised 3 degrees over a cool night... will be comfortable for swimming by tomorrow! It was interesting to learn about heat pumps and I'm proud to have fixed it!
