Thread: What am I missing?
    May 2014
    Westerly RI
    2
    What am I missing?
    After I shut the pool down to spray off the filter cartridges, I (for no reason) turned a three way Hayward valve (PSV3S) to off. I went ahead with cleaning the filters and returning all of the pieces back together, but can't get the valve returned to normal position.
    Am I missing Something? Is there a secret button I need to be pushing or something?
    thanks
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: What am I missing?
    I googled that valve. Seems there is a lock knob on top of it. Check to see if the lock knob got tightened a bit
    http://www.poolsupplyworld.com/Haywa...Favm7Aod2kIABw
    Divin Dave,
    May 2014
    Westerly RI
    2
    Thanks for looking. I am able to spin that knob pretty well so don't think that is it.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Thats strange.
    Its easy to take that thing apart to see if anything got stuck in there. Just remove the screws from the top and the whole assembly comes out of the housing.
    That valve is a very simple thing and springs and ball bearings will not go flying out, so dont worry. Other than the lock knob, the only thing that makes sense is some debris got between the internal part that rotates and the body of the valve and jammed it.
    Just be sure to get the O ring around the top seated properly and lubed when you put it back together.
    Divin Dave,
