Thread: Wall bolt size
    Question Wall bolt size
    I am putting up a 24 foot pool and am in need of the wall bolts. I have searched and searched and can not find the answer of the size. I know I need 27 of them but can I just buy at the hardware store or are they special?
    I know they need to be stainless steel but can anyone tell me length and size.
    Thanks
    Jun 2012
    western NY
    1,559
    Re: Wall bolt size
    Should be nothing special. Mine and most I have seen are 1/4-20 x 3/4" (1/4" diameter, 20 pitch thread count, 3/4" long under the bolt head). Pan head or round head will work. Get lock washers to put under the nuts.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Casey's Avatar
    SW PA
    10,421
    Re: Wall bolt size
    Make sure the nuts are on the outside when you put them on.
    Jun 2012
    western NY
    1,559
    Re: Wall bolt size
    Quote Originally Posted by Casey View Post
    Good point! Also put a couple of layers of duct tape over the screw heads on the inside.
    Re: Wall bolt size
    Great thanks
