Thread: Pump basket cover
    May 2014
    Tn
    18
    Pump basket cover
    Not quite sure where to put this. My pump basket cover was replaced this season and the new cover is so tight I have to use a bar to take it off and put it on. Any suggestion? It's the same part
    24 foot by 52 " above ground pool Hayward micro clear 25 sq ft cartridge filter Hayward powerflo lx 1.5 pump. Aquabot vacuum. Live in tennessee. Feeling like Walter white with my tf kit. Where's Jesse
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Pump basket cover
    Sounds normal. You don't have to go any tighter than hand tight unless it starts sucking air in. You might steel need some leverage to unscrew it, though.
    Good silicone lube (not teflon lube) will help a lot.
    Support the site
