Thread: Year round pool?
    tndtanaka's Avatar
    May 2014
    Riverside, CA
    14
    Year round pool?
    We live in sunny southern CA and have our first 50' lap pool. I was sad to discover that although the ambient temperatures in late October, November, even December are perfect, the water gets cold. Any advice how to reasonably heat in the winter months? I know the benefits of solar covers but even cut in several pieces I think they may be more pain than they are worth as I would have to handle it on my own and am not strong. I was also told that they would probably give me two months. I would like to achieve 77 degree water in the winter. We have a gas heater and I have been using it as needed now that the sun helps heat. In the spring the cost is manageable but in the winter probably not. My water temp was 68 in late October and I made the sorry mistake of swimming in it. It was just too cold. An automatic cover won't work well in our case as I have a raised deck with steps on one end. I tried Cover Free and due to high winds it did nothing but collect more insects. Anyone know anything about electric heat pumps? I was thinking of using the gas heater just for the spa and investing in an electric heat pump to extend my swim season from 5 months to 10, or at least that would be the goal. Our pool is not deep, 5' in the deep in the center with two shallow ends at 3 1/2 ft each, surface of pool is a light blue pebble. We do receive direct sun most of the day.
    25,000gal, IG, pebble, DE, variable speed, spa, SWG, 10/13 install, 50'x14'
    AlanE's Avatar
    Jun 2013
    Cape Haze Peninsula, Florida
    178
    Re: Year round pool?
    Maybe using a heat pump would be the most cost effective. Solar probably wouldn't be unless you had a large south facing roof. With your size pool, and making a lot of assumptions, you would need somewhere around a dozen 4x12 panels to make solar work for you.
    23.6x14 IG free form ~8K gallon, Pentair VS 3050 Intelliflo, GloBrite LED lighting w/IntelliBrite controller, Aztec Cobalt water tile. CLI Carolina Blue pebble finish, Bronze pool cage, 336 sqft Heliocol solar heating. Build Thread and landscaping Solar heating install
    tndtanaka's Avatar
    May 2014
    Riverside, CA
    14
    Thanks! I just purchased a couple of solar blankets I am going to cut into pieces to help hold in the gas heat and help me to manage alone. I think you are right about the heat pump. We will have to look into them. We don't have a large south facing roof so solar wouldn't work long enough.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Do you have natural gas? How expensive was it to heat the pool during the cold months? A heat pump will not draw in much heat when the outside ambient temps are in the 60's or below. The best thing is a cover to keep the heat in the water from the gas heater during the cold days.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    tndtanaka's Avatar
    May 2014
    Riverside, CA
    14
    Thanks! I didn't have a solar cover so I never tried heating it in the winter. I started heating in April and the bill wasn't too bad. I have a solar cover on order and I will see how the gas heater costs go. I plan to cut the cover in small sections as I won't be able to handle the cover otherwise, even with a reel.
