Thread: Confused in San Carlos
    Apr 2014
    San Carlos Mexico
    11
    I hope someone can help me, we have a SWG pool. Recently purchase the Taylor K 2006 test kit, so I could get accurate results.
    Here are today's results:
    FC 4.5
    PH 8.0
    TA 200ppm
    CH 775ppm
    CYA >100
    Salt level 7000
    Pool temp 88
    Is there anyway to get the test results into normal ranges with the salt level being so high? Last week we exchanged 6000gal of pool water w/ fresh and still have high levels. I'm not sure where to start! Muratic acid, water exchange ?
    No good pool resources down here, but now that I've found TFP I hope my problems will be getting much smaller. Thank you for your help!
    Becky
    12,600g, IG plaster, Sand Filter, Pentair 1.5HP, Eco-Matic SWG, Built 1/11. Polaris ATV
    Oct 2013
    Chapin, SC
    1,141
    Re: Confused in San Carlos
    A couple a questions-- how did your salt get so high? And how was it measured? Certainly not with the k-2006 test kit. What does your swg say the min and max salt levels are? I'm relatively certain it's not 7000. One more--if your cya is 100 today after replacing almost 50% of your water do you realize what is before?
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Welcome to TFP!
    Salt, CYA, and CH can only be lowered by water replacement, and all three need to be lowered significantly. TA can be lowered with muriatic acid, but I would wait until you are done replacing water and see what TA is at that point.
    38,305
    Welcome to TFP!!!
    With your CYA too high and your salt too high ... you will have to start with replacing more water. There really is no other option.
    Apr 2014
    San Carlos Mexico
    11
    My salt test kit is Taylor K-1766. And previous CYA results were >100.. I believe the salt got so high just because we arbitrarily put in too much at one time, we had left the pool unattended for 6 weeks and since that time it's been out of whack.
    Thank you for the quick response...guess we will order the water truck again to do a replacement.
    Becky
