Thread: Pentair Minimax Plus 400 Problem
    May 2013
    Falls Church, VA
    41
    After my usual getting rid of cob webs, leaves etc. my 13 year old heater fire right up again this season. It easily ran for 12 hours and the water was warm. But it stopped with the Heat indicator light out and the service light on with the associated clicking noise. I did more cleaning the next day and it worked for a couple of hours and then stopped. A tech at Pentair deduced it was a water flow problem since it works but shuts off after a while (thus not voltage/gas) and suggested I replace the flow valve assembly. I did that and it ran for six hours before stopping again with the same indicator lights. I think it ran longer than the previous try because the water had cooled down over several days. Anyone have anything like this or ideas whatís happening? It seems more heat oriented than flow oriented to me. Although the unit is old, itís still clean and heats well.
    11.5k gal, IG Plaster (2001), 1.5 HP Pentair Ultra-Flow Pump, Purex Triton FNS Plus 60 sqft DE filter
    ps0303's Avatar
    Jul 2011
    FL
    3,681
    Re: Pentair Minimax Plus 400 Problem
    Did you possible disturb some wires inside when cleaning? With the power of to the unit, check the wires and connectors and make sure they are securely fastened.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
