Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: My $20 fountain
    southern_gs's Avatar
    May 2014
    Georgia
    12
    My $20 fountain
    Posted last year a few times during our build. Then forgot my login and had to create new account. Need to add my info but we have 18x33 saltwater. Here is my latest addition- a custom fountain!. Just added an extra line to the return and control it via ball valves, so we can adjust the flow. Kids love it and it only cost me $20 to make it! Let me know if interested and I can send pics of the plumbing. This thing was a breeze and only took 1 hour to make. Happy Swimming
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,993
    Re: My $20 fountain
    Good job!
    Next up... a nipple to attach a pool noodle so you can use it like a firehouse to blast the kids.
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Re: My $20 fountain
    I'm almost done with my plumbing and want to add a fountain. But I do have a question...my plumbing is 2" PVC is this will be okay for a fountain? Or should I use something smaller?
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Re: My $20 fountain
    Shouldn't be a problem because you are going to reduce down to whatever size hole you drill to create the fountain. Just make sure and get you one of those PVC ball valves to control the flow. You don't want it to spray out of the pool.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    Richard320's Avatar
    Jan 2010
    18,993
    Re: My $20 fountain
    I'd reduce it at the T. A 1" ball valve is cheaper than a 2"
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Re: My $20 fountain
    Didn't consider that in my reply. As far as that goes, so will the pipe, elbows and end caps...
    May 2014
    United States
    5
    Re: My $20 fountain
    Can you send me some pics please.
    38,275
    Re: My $20 fountain
    Why not post up the pictures of the plumbing: How To Post Pictures
    May 2014
    Georgia
    12
    Re: My $20 fountain
    Will do. Have to take some more pics this evening and will post them tomorrow.
    May 2014
    Georgia
    12
    Re: My $20 fountain
    Good job!
    That is a FANTASTIC idea!!
    May 2014
    Georgia
    12
    Re: My $20 fountain
    Quote Originally Posted by Pysiek View Post
    If using a ball valve you should be fine with either. I ran all 1.5" and have more than enough flow, even with dual main drains. If you turn the fountain all the way "on" and turn "off" the return, it will shoot water 20 ft outside of the pool! Don't recommend that for lots of reasons, let alone the backpressure on the system. Of course the number of holes determines a lot of how the spray behaves. I went with a 24" piece and 20 holes. Real happy with the amount of arc and the noise of the water.
    Remember- running a fountain for extended periods also messes with your pH. Might have to test a little more than normal.
    18 x 33 resin AGP, 17K gal, Saltwater, 250lb sand filter, 1.5hp, main drains, PVC plumbing, custom fountain, wedding cake stairs. TF-100. Pool School.
    Best advice: Go through Pool School and follow BBB method. It will never let you down. Oh, and take a little time to clean your pool & test weekly...a little preventative maintenance goes a LONG way!
    Pysiek's Avatar
    Apr 2012
    419
    Re: My $20 fountain
    Quote Originally Posted by southern_gs View Post
    But I need to lower the TA and last year when I have intex pool the fountain helped me a lot
    May 2014
    Georgia
    12
    Re: My $20 fountain
    You are correct. I meant to say TA....not pH.
    Well, in the interest of causing less confusion ...
    As per PoolMath "To lower TA you reduce pH to 7.0-7.2 with acid and then aerate to increase pH."
    Pysiek's Avatar
    Apr 2012
    419
    Re: My $20 fountain
    Yes. By aerating you lower TA but raise pH.
    May 2014
    Georgia
    12
    Re: My $20 fountain
    Sure thing- I hoped to take some yesterday but had a school function for my 5-year old that ran until after dark. I will post some more pics today or tomorrow.
    May 2014
    Georgia
    12
    Re: My $20 fountain (MORE PICS)
    More Pics
    andyrob2215's Avatar
    May 2014
    Portage, Indiana
    127
    Re: My $20 fountain
    Thanks for the pics. I'm definitely doing this!
    21'x52 AGP 11200 Gal
    TFPC Method
    MermaidMama's Avatar
    Aug 2013
    Pennsylvania
    158
    Re: My $20 fountain
    That looks great!! Love that idea.
    MermaidMama
    18' Round x 52" Doughboy AGP
    Powerline XP Pump 1 HP
    Aquaview 17" Sand Filter
    TF-100 Test Kit
    JUST WAITING ON INSTALL!
    MermaidMama
    18' Round x 52" Doughboy AGP ~ TF-100 Test Kit
    Powerline XP Pump 1.5 HP ~ AquaView 20" Sand Filter ~
    Casey's Avatar
    SW PA
    10,438
    Re: My $20 fountain
    Coolness!
  20. Back To Top    #20
    May 2014
    Brentwood, CA
    76
    Re: My $20 fountain
    Where are the pics? My kids are going to love this and they will worship me!!! This is so cool!!!
    Intex 18' x 48" Ultra Frame Round Pool - AG, Intex Krystal Clear Model 28633EG 2500 Filter Pump, Intex Krystal Clear SWG #28663EG, TFT100 Test Kit, Hayward Skimmer
