Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Slamming process
    May 2014
    Plainsboro, nj
    28
    Slamming process
    Its 4th day of slamming the pool. My CYA is as low as 10 . I am trying to maintain FC 10. But during the day in sun light within in an hour FC is dropping to 5. I am actually adding little more than as per the goal.
    I would say it is better than yesterday , when it was dropping to 1 . I have used 75 121oz chlorine bottles and 30 64 oz bottles . Is it normal? CC is now fluctuating between 5-8 it was as high as 10-12. Water is still not clear. It is cloudy. Any recommendations or suggestions.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Slamming process
    Can you fill us in on some details about your pool? Gallons and filter type would be a big help.
    38,305
    What test kit are you using? How did you measure a CYA of 10ppm? You would not lose as much to the sun if the CYA was up around 30ppm.
    May 2014
    Plainsboro, nj
    28
    I have sand filter. 28000 gal pool.using TFT kit. CYA was lower than 10. I brought it to 20 now.
    38,305
    The TF-100 or K-2006 do not test the CYA down to 10ppm.
    May 2014
    Plainsboro, nj
    28
    I know i had to take it to pool store.
    May 2014
    Plainsboro, nj
    28
    Last year my pool was opened with lot of debris, green water. Slaming worked best . CYAwas high to 60. Today I started to see bottom of the pool to the deep end of the pool slightly. I can see the bottom at 3 ft since day 1
    38,305
    You have the best kit on the market and then went to the pool store to have them test your CYA ... which happens to be historically the test they are the worst at?
    Please, trust your own testing. If the dot never disappeared, then you know it is too low and need to add more ... adding only 10ppm more was probably a decent idea. Test it again in a week ... likely you will need to add 10ppm more.
    SW Indiana
    9,199
    It's not surprising that the cloudiness is slow to clear with a sand filter. It will get it if you just keep running it 24/7 and brush the pool daily as long as there is dirt on the bottom.
    You are losing a lot of chlorine to the sun. What was it like when you started? What is your pool surface?
    Have you checked your overnight chlorine loss? Measure the chlorine at some point after dark and then check it again in the morning before sunrise. This gives a good indication of the status of your pool.
    I'm a bit surprised that you have so much CC after adding so much chlorine to the pool. That may be just because I don't have experience with CC. I've had my pool since 05 and have never measured more than 1ppm CC even when I was battling the blackest, nastiest algae mess I've ever seen. Here is a little summary of my biggest algae battle to date. http://www.troublefreepool.com/threads/224-Algae-Diary 29.5 gallons of 6% bleach. My guess would be that you may have ammonia from CYA breakdown, but I know very little about that either. Might be worth a search.
    May 2014
    Plainsboro, nj
    28
    You are right about the test kit. Since it does not show below 20 i was not sure if i have 0 CYA or 10.
    But i decided to increase it to 20 . I added little more today to bring it to 30.
    Quote Originally Posted by JohnT View Post
    I was told when I have high CC it shows some organic growth in the pool. As i mentioned it happened last year as well. That was one of the reason we were thinking of changing the water. I did not expect this year i would get in to the same issue.
    Last year once everything was clear , then we never had issues with CC .
    We are planing to go for salt water chlorinator. Any recommendations or suggestions?
    May 2014
    Plainsboro, nj
    28
    By the way how would i test the water for ammonia?
    38,305
    If you add chlorine and a lot of CC show up in the test within 30 minutes, you can guess it is ammonia. Or go to the pet store and buy an ammonia test.
    May 2014
    Plainsboro, nj
    28
    Even if the water is positive to amonia , i understand from the research that i have to continue with slaming process. Is that right? I will perform overnight FC loss test tonight.
    38,305
    Yes. Keep SLAMing. No point in doing the OCLT until you have clear water and no CC.
    May 2014
    Plainsboro, nj
    28
    Oh ok thanks for the help.
    Hayward Pro Series Multi port filter
    18x36
    115 feet perimeter
    Vinyl liner
    TFTestkits
    May 2014
    Plainsboro, nj
    28
    I have not tested yet for ammonia but water has started getting clear . I still have CC 2 to 2.5. Not sure after clearing the entire water after spending so much money on chlorine bleach , would this Ammonia would develop again? Does it makes sense to replace the water? How much apprx would cost to do that for 28000 gal pool . Believe it or not i have spend $500 on bleach so far. Last year i spend same amt . And more on other chemicals as was not aware of the slaming process and pool stores keep giving me chemicals to clarify the pool.
    Also does developing ammonia has anything to do with filter or sand? What is the reason for developing ammonia in pool water?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    There is a process that takes place in some pools over winter when bacteria is present and consumes the CYA. The ammonia is a by-product of this process. Does not matter what type of filter you use.
    Love TFP? Become a
    TFP Supporter!
    Smykowski's Avatar
    Sep 2011
    3,065
    We think one of the prerequisites for CYA turning to ammonia is that FC needs to get to 0 over the winter. If you use our recommendation of closing late in the year when water temps get below 60, making sure FC is at SLAM level before covering it up, and then opening early, before the water temps get above 60, you should be fine.
    As long as you follow our recommended levels all summer, you won't have a problem, either.
    May 2014
    Plainsboro, nj
    28
    I will surely take care of all these all over summer and while closing the pool. So I understand replacing water is not required. Is that right.
  20. Back To Top    #20
    Smykowski's Avatar
    Sep 2011
    3,065
    Correct.
