Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: Algae Wars
    Firefly2000's Avatar
    Jul 2008
    Sydney, Australia
    38
    Algae Wars
    Great info on this site! Thanks to all contributors!
    I have a pool that's about 18 months old. For the last 9 months, I have been at war with blue/green algae and probably some black algae as well. The algae normally resides on the pool walls and floors and has clouded the water on 3 separate occasions (blooms). Brushing removes most of it, but I do get noticeable green stains on the blue pool surface.
    I have been through three different pool shops and been burnt by pool shop staff not know what they're talking about coupled with questionable results from their test equipment... Upon the advice of the pool shops we have tried shocking, algaecides, starver, brushing.... just about everything that everyone tells you to do. The problem is that the algae disappears for a short while and then quickly returns again.
    My chlorine levels have usually been somewhere between 3 and 6, and PH is always been around 7.5. The automated dosing system is working fine.
    I finally gave up on pool shop advice and decided to start educating myself. After reading through the information on the BBB method on this site, I think I've finally worked out why I've had such a major problem, and I thought I'd bounce my theory off you guys for comment...
    Around 9 months ago I changed pool shops as the original shop was now under new management. It was obvious that the new owner did not understand pool chemistry so I moved on. The new pool shop used a different testing method (strips) and insisted that there was no CYA in my pool, despite the fact that 1 week earlier CYA was around 30. So we added a significant quantity of CYA on two separate occasions (the test strips gave weird results on CYA). I recently moved on to a third pool shop (who also used the test strips, and their readings were 0 CYA!!! I took the same sample back to the first pool shop and CYA was now 100!)
    To cut a long story short I've recently had my water tested using a proper reliable test kit and CYA was in fact around 100.
    I'm now convinced that my CYA has been sitting around 100 for a couple of months now, and despite being winter, shocking & brushing, algae is still laughing at me!
    According to the Chlorine/CYA charts, because of the high CYA levels, my chlorine should be much higher than the 3-6 range that I've had it at... I can only conclude that the real problem has not been chlorine, phosphate or PH levels, but the high CYA levels!
    Am I correct?
    (I can't believe that the pool shops did not pick this up! I remember one pool shop telling me that it was a good thing to have high CYA - "the more the better"..)
    Do I start dumping water to resolve my problem? My theory is that I need to get CYA down to around 20-30 and then I can shock the pool and rid algae for ever!
    Daniel
    47000L (12500 gal)
    IG Quartzon Interior
    Rolachem Acid & Chlorine dosing
    Paramount In-floor cleaner
    1.5HP pump + Sand filter
    Solar heating under the great Aussie sun!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Algae Wars
    Yes, it does sound like your problem is high CYA; however, a full set of test results from a realiable source is always preferrerd.
    Lowering your CYA to a more managable level does not necessarily mean to take it below the recommended range. 30 to 50 is recommended if you use bleach ( 70 to 80 for a SWG).
    If your pool is in direct sun, you may even do better with a little higher CYA.
    You're done SLAMing when:
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Algae Wars
    Quote Originally Posted by Firefly2000
    Am I correct?
    I believe you are correct.
    Apparently your pool stores are as bad as ours.
    20-30 is probably too low. IMO, 40 is a good number to go for, but if I were in your situation I would go for about 70ppm to start with, then allow rainwater dilution etc. to lower it over time.
    One thing to be aware of is that many CYA tests are not accurate at high levels, so your 100ppm reading might really be higher than that. Often people will measure their water at 100ppm, drain half the water and find that the CYA is still 100ppm.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Algae Wars
    I feel your pain, sounds like almost identical to what I went thru with the pool stores, they know virtually nothing about the relationship between CYA and chlorine and algae.
    I agree with the above, try a partial drain and to get it lower, say 60 or 70 and then see what happens. I ran with 70 all last summer, shocked once and after that was able to maintain the FC at 8 or so and never had anymore problems. This year I was able to get it down to 40-50.
    Good luck!
    Jun 2008
    Marana, AZ
    347
    Re: Algae Wars
    I agree with the others. From everything I've read, with under 30 CYA you would be using up chlorine for no reason, getting it burned off quickly.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Re: Algae Wars
    Everyone has given great advice, all that is left to say is Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Jul 2008
    Sydney, Australia
    38
    Re: Algae Wars
    Thanks everyone for your input. I'll start working on lowering my CYA.
    I would also like to add that I have a water feature in one corner of the pool that runs twice a day powered by the pool filter pump. Water gets pumped into a pot and trickles down the side of it into a small elevated shallow (8 inches deep) pond. Once the pond fills up it flows over a weir and into the pool (about another 8 inch drop into the pool).
    Would having such a water feature running every day contribute to any problems for me? Apart from the algae wars, I have also struggled with low TA (usually around 50-80).
    I've attached a picture of the water feature.
    Thanks
    Daniel
    47000L (12500 gal)
    11,969
    Re: Algae Wars
    Actually, having your TA in that range will help keep your PH in range. If your TA was over 100 or so, your water feature could actually cause a PH rise.
    That's a neat feature...never seen anything like it.
    When do we see the REST of the pool??????
    Jul 2008
    Sydney, Australia
    38
    Re: Algae Wars
    Ok. Here's the rest of the pool. We have stepping stones alongside the house as an added feature and also for access.
    Pavers are all Australian Limestone. Photos are about 12 months old. The fences are now almost covered up by the plants.
    Daniel
    47000L (12500 gal)
    Oct 2007
    Cedar Hill, TN
    252
    Re: Algae Wars
    LOVE the stepping stones!!!
    What a clever idea.
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    11,969
    Re: Algae Wars
    The stepping stones are cool. I also like the clear fence, really keeps the area open and spacious looking. Very nice! Sean should put it in the slide show.
    Mar 2008
    Central VA
    328
    Re: Algae Wars
    Man, that is nice! Love the stepping stones and the water feature!
    Hey, check out the Pool School section from the home page, TA is pretty easy to bring up if you need to...you may have seen it already but if not it's in some of the basic chemistry posts.
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator.com/
    Rocklin, Ca
    467
    Re: Algae Wars
    Those stepping stones look pretty cool. That certainly would not be permitted here in the states. Most places have some rules about how close the waters edge can be from the house. 5' is fairly typical.
    I hope that glass is tempered. It looks like it is from the picture.
    Boy I miss Australia. I've been to Sydney and Cairns twice.
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
    Jul 2008
    Sydney, Australia
    38
    Re: Algae Wars
    We actually had to modify the foundations of the house to be able to build the pool that close to the house. We had to underpin the corners of the bay window with 600mm (2' deep) peers to take the load of the house to a point below the excavation of the step stone area. So, from a structural perspective this can actually be done successfully, and I would be surprised if local authorities in the US would not allow this...
    The glass is what we call "safety" glass or "toughened" glass here in Australia. It's 12mm thick (just under 0.5 inches) and is very difficult to break. With pool fencing absolutely mandatory here, glass is becoming more popular, although it is rather expensive.
    Daniel
    47000L (12500 gal)
    Jul 2008
    Sydney, Australia
    38
    Re: Algae Wars
    Six weeks since my first post, pool has been crystal clear for about 4 weeks now. My CYA levels are now around 40-50 and the algae is staying away!
    This is a BIG win for me after months of frustration! Thanks all for you help.
    I still have some green stains on the walls in places. There are also some darkish (green/brown) patches in the bottom of the pool (particularly in the shady areas). Brushing does not appear to have much affect. At the moment it's not getting any worse, and it might even be fading. I'm hoping that it's just ingrained algae (hopefully dead) that will eventually go away with correct FC and brushing every now and then....
    Any thoughts?
    Daniel
    47000L (12500 gal)
    Jul 2008
    Indianapolis, Indiana
    7
    Re: Algae Wars
    I had some stains on my pool that I thought wouldn't go away. but with constant contact with the chlorine in the water they slowly disappeared.
    Very nice pool design. I can see with the small yard why you would go to the extra effort to strengthen the foundation to get it closer to the house. Otherwise you wouldn't have more then a rectangular lap pool. Great job.
    18' AG Vinyl Pool (7,500 gal)
    1.5 HP Hayward pump and sand filter 150#
    Using the BBB Method
    Taylor K-2006 test kit
    30,432
    Re: Algae Wars
    Keep your FC up a little higher than called for and the stains will slowly fade away. Not always, but very, very, likely. It may take a couple of weeks or more but they'll disappear.
    Jul 2008
    Sydney, Australia
    38
    Re: Algae Wars
    Thanks for the replies. I forgot to mention in my previous post that I followed the advice on this forum... TF100, shock, brushing etc... I've done so much reading here lately. To those of you that are new around here, read, read, read and follow advice. I'm now looking forward to a (hopefully) trouble free pool season, which should start around the end of September for me!
    I'm currently running FC at around 8-10, with CYA at around 45-50. All other numbers are good.
    Duraleigh, should this FC level be high enough for these stains to theoretically disappear after say a month or so?
    It's still winter over here and the sun is still fairly low in the sky. Only about 2/3 of the pool gets sunshine, so it's not hard to keep the FC levels high.
    Daniel
    47000L (12500 gal)
    30,432
    Re: Algae Wars
    Yes, I'd say that's very reasonable. If they aren't gone or greatly diminished after a month, then it's most likely not an organic stain. My bet is they will be gone.........maybe even a little sooner if you keep your FC up there where it is now....then you can let it drift back down to 3-5 or so for the rest of the summer.
  20. Back To Top    #20
    11,969
    Re: Algae Wars
    I had tea-colored stains for several years, running with a higher FC and finally they are faded to the point where only I can see them, LOL, and most of the time even I can't. I would say a few months at the higher FC and they should fade rather well. Glad to hear your good news!
