Results 1 to 10 of 10
Thread: CYA and FC question
    astronaut888's Avatar
    Jun 2013
    southeast
    118
    CYA and FC question
    Forgive the basic question.
    Presently
    CYA 50 (may be slightly lower)
    TA 100
    pH 7.5
    FC 7 - tested this morning at dawn
    CC 0 - every now and again will turn slightly pink w 003 - but, subsequent tests don't turn - so, could be 0.5
    Water looks beautiful and clear (!)
    Depending on the day's weather, I have been adding anywhere between 30 and 90oz(ish) 8.25% bleach in the evenings [ 30 oz raises FC 1 ]
    With respect to FC levels
    Pool School suggests between 4 and 6 FC for a CYA of 50 - I'm not entirely sure that CYA is 50 and not closer to 40 as I have a **** of a time determining whether or not I can still see that black dot!!
    I've erred on the side of assuming it is higher as to not let FC get too low
    My question is : I know I never want it to go below 4 (ever, right?) - but, raising to only 6 concerns me, as it does get down to 4 on sunny days, which, to me, Is dangerously close to getting TOO low
    So, should I be raising HIGHER than 6 in the evenings? i.e., should I target 7 or 8 with my bleach additions ?
    Also, There hasn't really been any use of he pool this season yet and I have a party coming up this weekend with lots of folks and kids and the pool is going to be rocking
    Would it be advisable to kick the FC up a notch before folks show up - get it to 7 or 8 before experiencing such a bather load?
    I have yet to see how the pool reacts to folks actually USING it (!)
    Thanks!!
    20K gal, IG vinyl, 1 1/2 HP Hayward Super Pump , 100lb sand, installed 2000 - new liner/filter/pump March 2014
    TF-100 test kit
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: CYA and FC question
    The pool will not turn green if you let the FC get to 3 for a few hours before you add chlorine. LOL I'm gonna tease you a little bit.
    We have a range- a cushion if you will. We stress "ALWAYS" and "NEVER LET IT" because we want people to "get to know their pool" and be diligent - because it's oversight and negligence that leads to problems.
    The avg loss is 2ppm per day. This is an avg. Get to know your pool. Try 7 or 8 and see where you end up. Maybe it will be a more comfortable place for you.
    Yes for a party I'd even go to 10. Test when party is over and bump it back up. That's what I do.
    Have a fun party!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The chart you are using from pool school does round up a bit, with a CYA of 50, the actual minimum you want to stay above is 3.7 ppm, and even that does not mean if you drop below it a little that you will have problems, just that the chances go up. If your CYA number is a little below 50 then that number is likely closer to 3.5 or less for minimum FC. Having said that I agree with the suggested target numbers mentioned by Frustratedpoolmom
    Jun 2013
    southeast
    118
    Thanks for replies!
    I really don't know what the concern would be in keeping the FC a bit higher, honestly. Not suggesting that there isn't a concern, just that I am unaware of what the concern would be, other than maybe using more product than I really needed - however, If I see that I am losing , say, 2 PPM per day - what would be the difference if this loss was from 6 to 4 OR 8 to 6?
    TF-100 test kit
    If your pool goes from 6 to 4 during a typical day, and you instead started at 8 you would lose more than 2 ppm of chlorine. The amount of chlorine used is a percentage of your starting level.
    Jun 2013
    southeast
    118
    Quote Originally Posted by JasonLion View Post
    so, would be, in fact, a waste of money/bleach essentially?
    TF-100 test kit
    Right. It might not be all that large of a waste, but it would be some chorine wasted.
    Jun 2013
    southeast
    118
    gonna use this thread to test and see if i am able to properly upload an image
    thanks for entertaining me
    TF-100 test kit
    11,969
    Keep the raccoon out of the truck, and the POOL! Gorgeous!
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Beautiful pool....I wish I had your liner color! Love that color blue!
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
