Thread: Pool Math Question
    Aug 2008
    Hebron, CT
    79
    Pool Math Question
    In the Suggested FC Levels section in the Pool Math Table toward the bottom, the following is shown:
    SWG:3 Normal:5 to 9 Shock:24 Mustard Algae Shock:34
    Suggested target FC levels based on the current CYA level for outdoor pools.
    Note: Be careful if your CYA is really and truly zero!
    My question is a clarifying one- Is this basically saying (in this example) that based on the numbers entered for all the other testing categories (PH, TA, CH, CYA, Salt etc...) that with a SWG, FC should be kept at 3 and normal range is considered 5 to 9 and to shock you would target 24?
    Thanks!
    22,500 gal Lagoon shaped inground pool, vinyl liner, Hayward 4800 DE Filter, Hayward 1.5 HP super pump, Aqua Heat Pump, Nexus Pure SWG, Dolphin Triton PS, Hebron, CT
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Pool Math Question
    Yes.
    The SWG level is a minimum, you never want FC to go below there. Most people aim a little higher so they will have some margin in case it goes lower than expected. The normal range is for people who don't have a SWG, and again the first number is a minimum that you never want to go below.
