Thread: Cartridge Filter Cleaning Question
    I am helping a neighbor turn around his neglected pool. He has very high CYA level (>100+) and he has alge in pool...we are draining water and replacing (1/3 of pool at a time to avoid ground water pushing up his pool floor, etc)....Then we will SLAM it when I get the CYA level down to 30-40 range.
    The real question I have is this: He as several old(ish) cartridge filters that have been sitting outside for months in the Florida sun...they look pretty dirty but otherwise appear intact. I am not sure of the age of the filters...I will find out later when I go over to his house to check on the water changing process and to retest his CYA level
    Should I try to salvage these old filters with some filter cleaner solution (the usual yellow stuff available in Home Depot, etc) and lots of hosing down? Or should I have him get a new one?
    Thanks!
    (His pool is 13K gallon, concrete, Using Tricor Tablets for Cl.)....simple single speed pump and cartridge filter).
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Cartridge Filter Cleaning Question
    I would go with the dishwasher soap soaking overnight, instructions can be found in Pool School. You'll know once they are in the filter if they are salvageable, after cleaning the pressure should be good, return flow good. If they're not, you'll know it. High PSI and low flow from returns. Soaking with the solution really works and I've salvaged some unsightly ones.
    Thanks for info! I will try and report back!
