Thread: Pump just sitting there...
    May 2013
    Janesville WI
    74
    Got sand filter for Intex and have the original pump just sitting around. Looking to see if anyone has used two pump setup. Want to use the original pump for solar heater and cleaning, anyone use two pumps and not cut extra holes in liner? was thinking about a pvc setup.....
    Intex 18x48/2650 Sand/56601E SWG
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Pump just sitting there...
    I'm planning on using my spare intex pump as the pump for my solar heater... When I got my pool, it was the first thing I thought about replacing... But I didn't want to sell it so I repurposed it..
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
