- Aug 6, 2012
- 14
I've been working on opening our pool for the past two weeks. Mostly just trying to get all the leaves and pecans out for the first several days and filtering the water! (Pool is under a large pecan tree). Anyway, I'd gotten all the leaves out and the pool was clearing up but still cloudy and couldn't quite see the bottom - I could see a little darkness if there were leaves there but not really the liner. This morning I put some shock in - Just a 1 lb bag. And this afternoon I checked the chemical levels and here's what I got. (I took the water to the pool store because I was out of the CYA reagent. Also, my test says that I had no chlorine).
Here are the pool store's numbers:
Free Chlorine - 0
PH - 7.4
TA -110
CYA - 20
CH - 200
Salt - 2000
Phosphates - 500
My pool is 13' X 26' X 52" (11,400 Gal) - Using a SWG and a 175 lb Sand Filter w/ a 1.5HP pump.
I came home and added 2 gallons of bleach (8.25%). Then added 45 oz of CYA (In a stocking by the return). I kept squeezing the stocking every few minutes to help it dissolve. I went inside for maybe 30-45 min and when I came back out my water had gone from "getting clearer" back to brownish "lake water". Ugh!! What's up with that??
The only other thing that I can think may have done something is that after I added the bleach and the CYA I turned off the pump for about 45 min. and had my husband take the swg cell to have it checked out because my "check cell" light kept coming on. After he got home, we hooked it all back up and turned the pump on. (THEN I went inside for 30 min. and came back to a brown pool.)
Additional info: I was surprised that there was no chlorine in my pool after adding shock this morning - however, I realized later that I didn't have my generator running so it was only filtering and not generating chlorine.
I've also added 2 - 40 lb. bags of salt this evening.
About an hour ago I tested my chlorine and ph levels.
Chlorine was 10 and ph was 4.2.
I added 50 oz. of borax (weight).
Any ideas would be greatly appreciated.
Free Chlorine - 0
PH - 7.4
TA -110
CYA - 20
CH - 200
Salt - 2000
Phosphates - 500
