Thread: First opening
    Mar 2013
    South Windsor ,CT
    22
    First opening
    This is the first year opening my pool . Previous owner opened it for me last year .
    Readings are
    TA 80
    Ch120
    PH7.5
    FC1.5
    CYA20
    Is it poss to have FC left from last year? Fill water tap tested no FC . I closed late sept used tarp cover. I brought it up to slam level b4 closing last year. Water is clean and beautiful thanks to TFP .What steps should I take first . I am currently using chlor-brite dichlor to bring up FC Due to purchasing SWG in offseason that will be installed after Memorial Day .
    21000 vinyl IG
    TF100
    Jacuzzi sand filter
    Aquabot AWD
    Jandy aquapureIE SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    Re: First opening
    Is the water clear?
    If so, it sounds like you closed it properly.
    Mar 2013
    South Windsor ,CT
    22
    Re: First opening
    Perfectly clear and passed oclt
    21000 vinyl IG
    TF100
    Jacuzzi sand filter
    Aquabot AWD
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: First opening
    Yes possible. I open with chlorine from last season all the time. Especially with a tarp cover. Less like if one were to use a mesh cover.
