Results 1 to 13 of 13
Thread: Intex better than sand filter?
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    We moved into this house and they had a 22' x 52" intex pool with a 2500 gal/hr intex cartridge pump & filter.
    I didn't think it was doing the trick and I didn't really know much about flow rate and that kind of thing, just that I had had pools before and it thought these intex was inadequate.
    I bought a used sand filter and a 1 hp pump that has had some issues with leaks and debris coming through the return.
    While working on my sand filter, I had to hook up the intex filter... And I have to say, I like it a whole lot better. It doesn't leak, the connects are modular and don't require modification.
    There are many intex users here, what do you think about these cartridge filters? Are they really adequate for 5 bathers a day? Pool season starts this weekend!
    Intex 22' x 52" - Intex Krystal Clear Sand Filter Pump - flow rate: 2,150 gal per hour
    TFTest Kits TF-100
    Waiting to stop relocating until I build my dream pool!
    Re: Intex better than sand filter?
    An Intex cartridge filter is not going to work at all well for a pool that size. We have had large numbers of posts from people having problems with those filters.
    Sep 2007
    Shoreview, MN
    11
    I agree. I owned a 15' frame and an 18' easy-set and had difficulties keeping them clean with the intex filter.
    At one point I calculated the area of the filter and came up with something around 15-20 sqft. That isn't going to cut it with 5 bathers in a 10,000+ gallon pool.
    18'x33' AG, 1.5 hp pump, 120 ft2 cartridge filter, BBB method
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Is the issue the filtration? Because At 2500 gallons per hour that's not too far away from a 1 hp Hayward pump is, is it?
    TFTest Kits TF-100
    The pump is fine, it is the cartridge filter that is the problem.
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    I saw some at the pool store that said that they last "all season long" Is it possible to buy a better filter?
    TFTest Kits TF-100
    Any filter is better than an Intex cartridge filter. The most affordable filter would be an Intex sand filter. A 19" sand filter would be even better.
    Aug 2011
    Virginia Beach
    295
    The second best thing I've bought for my pools is the sand filter/pump combo. I use the pump that came with the filter to get the water flowing in a whirlpool, it helps get the dirt to the middle of the pool which makes it easier to clean up. This is our 3rd "temporary" pool, and ALL of the pumps/filters that came with them were pathetically sized for the job. Go with the sand filter, you won't regret it- modified connections and all.
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Not even a unicell filter will do the trick eh?
    TFTest Kits TF-100
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    How many ways can I patch this thing? http://www.youtube.com/watch?v=
    Repair or replace?
    TFTest Kits TF-100
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Quote Originally Posted by JasonLion View Post
    Think this is adequate? http://www.walmart.com/ip/Intex-Krys...-Pump/33153775
    TFTest Kits TF-100
    Yes, that filter is a good deal and reasonable for your pool.
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Thanks- I did buy that and hopefully it will do they trick. For some reason it is only a 2100 gph pump.
    TFTest Kits TF-100
